I test every batch of fuel and United is always between E85 and E90. I did get an E93 once but these changes seem minor to the tune. If I used Caltex it would run a bit richer.
how do you test?
i've only ever seen E80 - E83 with my GM Ethanol content sensor.... never seen United E85 higher (did see E84 briefly once but settled after 30secs or so at E83)
Eflex for me when i used it was always bang on E70 - i made 15rwkw more on E85.
  • 6 months later...
Making use of the United servo up the road from my place. Paying $1.14L which isn't bad.
Back on the road again after a head gasket change and new gearbox. Engine feels stronger off boost so I think comp is slightly up a bit after the new gasket went in.
Went for a cruise on friday night with some of the boys and felt great :)
Back on the dyno in a couple of weeks to test out the new gasket with more boost, see where this turbo runs out of puff.
Woo hoo! Cant wait....
Wow I've been beltng through this build in the last 2-3 days like a book you just can't put down. This story has it all, highs, lows, external gates :P
Seriously man what an awesome car you've built, hats off to you. Hands down the most insane GTST I have ever seen, I love it. For god's sake just make sure that now you just concentrate on getting your money's worth out of it by having fun driving it! ;)
Thanks Nick! Driving it is always fun. Definitely need to do more of it :yes:
Maybe you can take me for a run without breaking it this time :P AND maybe ill try do the same lolz
Oh no. What did they do you for? :( I hope they didn't smmash you too badly, but with that huge mofo hanging off the hotside of the engine..... hmm haha
This is why they shouldn't be driven on long weekends. They're everywhere.
The problem is I'm 100% sure Dave wasn't doing anything stupid or hooning if you will
The fact it's an import is the only reason
The amount of smoke billowing bald tyre no brake light cars out there on the road that don't get stopped is frankly dangerous
Dave next eastern creek track day you should come an unleash the beast
I told him my car would produce less emissions than his patrol car :) Thing is most coppers have no idea what they are looking at, so they just issue you with a DECC notice.
Could have been 100 times worse though. I got off fairly lightly considering he flat out laughed at me when I popped the bonnet lol
an older head will serve you better dave. There are times I just dont drive the chair for this very reason.
Mind you putting around in my tweed hat raises their eyebrows a bit. I have had them do a ubolt to hunt me down then just shake their head and drive off when they see the old foge in the tweed cap driving.
The walking stick is my second line of defence, if the cap doesnt swing it the cane usually does.
Growing old isnt all shit and shrapnel.
  • Like 1
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
