Also spotted EMSTA tonight parked around the corner from my place in Lakeside Pakenham.
woo yeah - another one! was working a bit late tonight. left at around 7pm ish. The townhouse that it was parked in front of is part of our office (only till may though)
Seen that around a few times... isnt there someone on here with that as a userid?
Pretty sure its a chick...
EDIT::
oh here ya go
http://www.skylinesaustralia.com/forums/m16407.html
Spotted a White R33 - at roughly 12:15am passing Shell on Princes Highway, Hallam.
I was pulling a u-turn in a truck so I couldn't really have a proper look..
lies!!! just pull the e-brake and do the scandanavian flick - that should do the trick
lol, it's kinda hard to pull the e-brake since it's air brakes and not a proper e-brake that you just pull up..
Spotted a very clean white R33 GTS-T driving down Spencer St from Dynon Rd towards city at around 1830 today.
Stood out, must have been a girl's car. Had hot pink plates and huge hot pink "NISMO" scrawled across the sides. Was driving too fast to notice her plates :(
Spotted a Blue 34 turning right from Princess Hwy onto Westall Rd at the same time a White 34 was turning left off Westall Rd onto Princess Hwy at around 7:45am... ...Blue had SAU stickers (UKBxxx)...
A few min later on heatherton spotted a silver 34 turned off Springvale Rd and then into Olympic Ave...
Then on the way home spotted a White 33 that changed lanes in front of me a little close to my bumper... ...(UFIxxx I think)...
Also at some point saw a white 32... ...lots of black and brown around the zorst...
Emsta knows nothing about drucks :banana:
At least you can admit it! :banana:
Probably making sure that you notice him/her.. lol :/
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
