agreed!!
and Crown isnt secure by any means
people park ON other cars all the time which is always lovely
Last time I parked in 'Secure Parking' ie thats the name of the carpark.. they had 3 breakins on one day.. NOICE
..apparently only one camera in the whole place is working..
Spotted a R32 GTST at the corner of Wellington and Napoleon roads last night at about 9:30. Also saw a S1 R33 GTST on Burwood Hwy just passed Springvale Rd at about 10:15, license plates STALEY.
agreed!!
sorry guys i didnt realise it was as bad as that.. :worship: ash mentioned it to me about how many cars get stolen from the carpark every week!
apologies
like 1/2 hour ago saw s2 33 on princes hwy near wellington road w/ sau sticke on rear 1/4 window
then down eleanora rd saw white 32 with wide body kit like 4 cars infront
couldnt get close enuff to check it out proply.
ne one from here.. lookked HOT!!!!!
Seems like alot of peolpe on wellington road... I work on there im always driving around there anyone spot me R32 Bayside Blue paint Black Bonnet?
I've seen a few R33's around on wellington rd and the freeway just never remember about them by the time i get home lol
Edited by cosmokram3r
Spotted a white 33 in the Epping area tonight.... had a huge scoop in the... middle.... of the bonnet..
Anyhoo I spotted Babia last week in a city carpark :domokun:
Saw an awesome looking stealthy black S15 on err Flemington Rd this morning too :domokun:
And some tards parking way too close to a grey 33 in a Russell St carpark tonight pfft
Went to pool room tonight.. drove in and i saw lots of skylines lol, about 4 R33's red/white/silver, a black 4-door 34 with a bodykit which looked really hot, another silver R34, and a Black R32 turbo who came in as i did had NISMO stickers all over it =P
Burwood hwy at 1am saw in rear view mirror blue HIDS waited for it to go past and was a white r33 possibly that one who lives near ferntree gully maccas if your on SAU. =)
The best car park in the CBD with proper security camera coverage is the one at Fed [].
i'm banned from there! :domokun:
a f**king DAEWOO in front of me dropped a "burnout" and when they looked at the cameras which car do you think they assumed it was and decided to take down the rego????
:domokun:
SKYL1N, that was me at balwyn maccas. R33 I have, was gonna park and say hi but had chick with me in the car... you know how it goes lol
prob best you didnt.. we had been there waaaay to long anyway.. somehow standing at maccas car parks just drain time out of you.
lol
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
