Drag race Orange Yellow Guidaro vs Gunmetal Vanquish. 840am Melb cup day from lights heading north under Richmond station up towards Bridge Rd. Guiardo was winning by a car length before MCG carpark. If I only had a fast to start up camera...
nice looking 33 gtst s2 with white rims today...
also 2 red gtt's about 4 33's and a guy in a black 32 that tried to race me on punt road, on cup day.... not a great idea :D
i've seen that pink vlt around too... :D
hahaha yeah i see that guy around quite frequently. its a NA Turbo. not exactly my style but each to their own.
saw him again at delahey maccas a few nights ago with his unbelievable bright pink neons. hmmmmm
Edited by PSI.33
Just back from a long weekend... Spotted lots of Skylines..
Saturday..
Dark/blue 33 in the morning on the westgate, SAU stickers, I gave you a wave.
A white 33 at the start of the great ocean road in Torquay.
A blue 34 GT-R in Apollo Bay.
Sunday..
White 33 GT-R on the road between Dunkeld and Halls Gap in the Grampians
Monday..
A grey 34 4 door in Ballarat.
A white 33 GTS-T in the car park at the Novatel resort at Creswick.
i've seen that pink vlt around too... :huh:
Saw that vl turbo on friday night on kings road outside delahey maccas... and saw a yellow one on main road east in st albans
Spotted a white 33 parked near Subway at Knox today - had SAU stickers and green P's
HI!!
Thats Leigh! (4door_33gts) he works at pizza hut next to subway, go get a free pizza next time! :laughing-smiley-014:
Edited by b3za
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
