Was at a set of lights and along side i hear 'doof doof' so i just look straight ahead but I cant help but notice in my peripheries that the driver with his arm out the window was giving me 'the STARE' for about 10seconds mind you which is not comfortable for a heterosexual.
Anyways turned out to be some ford foulcum with [iAMFPV] plates
Is anyone else sick of "the stare" unless its a member of the opposite sex?
hahahaha yea man i got 100 of those last night people stare at you like they want to start trouble with you when will they learn
spotted a cop on my way home from racepace yesterday... she almost pulled out in front of me (then decided against it as there was NO room) causing me to jump on the anchors and give her a 'you gotta be kidding' stare and head shake... which I then decided was a pretty bad idea lol
saw like skylines on beach rd last night.
orange 33, silver 33, black 34, black 34 4dr, and 2 really nige 33gtst's
i nearly had an acco with a cop the other day too... he was turning into a street in front of me when part of his arial fell off so he stopped and got out as quick as he could.... forgetting 1 tiny detail... THE HANDBRAKE!!!... lucky i wan't going fast and was able to stop as his car came reversing infront of me...
i'm sure it would have somehow been my fault :D
was on hoddle street last night at about 6:30pm stuck in the peak hour traffic, had a white r33 gtr pull up next to me and then the next lane over a r34
and i was thinking 'what are the chances 3 skylines in a row in peak hour!
spotted a chick in a 33 with white rims on princess hwy, near webb st at about 7.30 yesterday
were you in the grey 32 I think its my shit box your talking about? If so hi :)
spotted a white R33 Series I on the way to work on Bangholme rd i think thats how u spell it...... Anyway he was pulled over 3 people out side the car looking at the car prob took that corner trying to show off and lost it and stacked trying to show off to his mates, would not surprise me its a very dangerous corner.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
