Spotted a wine R33 last night about 7pm-ish in Monbulk... we both turned down Old Emerald Rd and then I pulled into a driveway.
Also a gray R33 in the Eureka carpark, Southgate... seen it there a few times now... I think works at HWT.
Edited by Samon
Spotted a purple r33 gtr that lives a couple of houses down from me in Rowville. Number plate starts with UX
You usually park outside my house to keep my r34 company
You also work at the same place as i do (NEC) i've seen your car in the car park
Really tempted to put some plastx on your lights. It would make your line look new!
Hopefully i'll see you around
hehehe do it for teh lolz
Spotted a nice white 33 with a carbon bonnet as i was driving to work this morning on the monash near Narre warren exited at Warrigal. Looks tops
Also hi to the dude leaving Narre Shell on narre north road..
Was that you in the skyline shirt on the phone as i was leaving the Shell??
If so hi dude.
Edited by kspots08
saw a red r35 gtr SPEC-V plates on kitchen road out side a panel beaters i was driving passed in a thrifty truck and then i turned on to greens rd and had to slow down as i saw it coming up behind and wanted another look lol
on doncaster road had SKYL1N pull up behind me - i was in the red r33
5 minutes earlier I saw a silver r35 GTR with yellow NSW plates parked near the corner of belmore and balwyn road, took a picture on my phone - still yet to check how it came out >,<
Pulled in to 7-11 on doncaster road tonight at about 10pm, came out of the store and saw a white 4 door R34 pulled over by the undercovers, gettin a 'please explain' about how loud the exhaust was. Waited til the cop got back out of his car before i babied my car out of there in 3rd. Pretty freakin unlucky man, hope your on here, want to know how it went. Cop was like "rev your engine........thats just a bit loud dont you think?". Looked like a nice car you got there too man......
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
