spotted lukeb on stud road at around 12:40 today. gave a thumbs up but dont think you saw it lol :blush:
then at bout 1:10 saw a silver 2 dr 34 on stud, head towards stud/highstreet lights, nice kit...didn't catch plates
Lol, saw you too. I was too busy concentrating on the cars in front to look towards you otherwise i would have returned the thumbs up.
I thought you had a GTT? Was thinking to myself how the hell does a p plater get away with that especially in the knox area lol
Edited by lukebaldan
saw a black r34 4 door with sau stickers p plates and forsale sticker on it get pulled over by a ve wagon cop car with a trailer on the monash freeway right infront of me at the narre warren north rd onramp inbound.
Saw R31WGN Blue/Silver two tone today twice.
On the way to work turning at highbury/warrigul rd then turning at highbury/middleborough rd on the way home.
Very niiiice!
Also on Saturday spotted a white R30/R31? sedan parked out back between repco & re auto parts centre road.
It looked sik!
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
