Spotted at least 4-5 skylines last night at the New Moon opening day in Ballarat :action-smiley-069:
1x black r33 series 2
1x rice white and blue r33 with supra wing
1x black r32 GTR
1x black r33 series 1, stock standard
1x mottled green/pearl white r34 sedan
That accounts for almost all of the skylines in Ballarat :P
Black, stickered (Dutton stickers most notable) R35 on Barkly Street St Kilda yesterday about 6pm'ish. First public road sighting would you believe, F'n beautiful.
this is round the corner from my work and about the time I head home and I didn't see shit... I still haven't seen a bloody 35 on the road! :P
I see a million 911's everyday but no GTR's... surely there must be more people with taste out there :action-smiley-069:
Cruised alongside a really nice sounding silver 32 last night on Diamond Creek Rd, Greensborough. Gave each other 'the nod', a few kind words and a wave and a beep upon going our seperate ways. Skyline comradery never ceases to amaze me. We are a truly great breed I believe.
Oh haha really? In the mornings you go up Greensborough Road and in the evenings you go from Grimshaw Street?
Oh, well then maybe it wasn't me! I thought you meant from Greensborough road into Grimshaw st, which I occassionally do in the evenings.
Must be some more white 33s in our hood :)
Spotted: Red 33 and Balck 33 at International House in box hill, red one had sau sticker
Astroboy... i was commenting the other day that i never see unco around our area. ... i dont think i've seen you around here either!
Today saw nice clean white R34 gt-t i believe (rear skyline badge taken off), nice looking car with aftermarket spoiler, had an SAU sticker. Also had green P's, gave the thumbs up as went by the first time round VUT Footscray. Was approx between 7:00 - 7:15pm outbound from city on Dynon Rd, stayed together all the way down ballarat rd, i turned off afterwards near Sunshine.
Same time saw a tough looking white supra behind us with some insane camber! a dark coloured 180sx i believe was also behind for a while, had a chasers sticker. Thought i was on a cruise all of a sudden :) All sensible drivers.
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
