four r33 in sth yarra today.
blue one parked on chapel st.
white parked in the side road
two red ones passing by eye contacted wit one of em ? im the guy in the silver. :banana:
silver 34 on punt rd?
Wynn, is your R34 Black?
:D ...yesss... :P
On another note...Spotted between 2.45-3.30...
  1. white 33 - glenferrie rd turning left towards caulfield
  2. blue 180 - dandy rd going towards caulfield
  3. black/blue silvia - kensington rd cnr dynon
  4. white 32 - ballarat rd turning right into ashley st
  5. black 350z - ballarat/mcintyre rd going towards st albans rd
  6. pewter s15 - as above
  7. black 180 - ballarat rd near ring rd on ramp going towards caroline springs direction
  8. silver (?) 300zx followed by blue wrx - turning right into cairn lea dve
:P ohh, so many :woot:
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
