four r33 in sth yarra today.
blue one parked on chapel st.
white parked in the side road
two red ones passing by eye contacted wit one of em ? im the guy in the silver. :banana:
silver 34 on punt rd?
Wynn, is your R34 Black?
:D ...yesss... :P
On another note...Spotted between 2.45-3.30...
  1. white 33 - glenferrie rd turning left towards caulfield
  2. blue 180 - dandy rd going towards caulfield
  3. black/blue silvia - kensington rd cnr dynon
  4. white 32 - ballarat rd turning right into ashley st
  5. black 350z - ballarat/mcintyre rd going towards st albans rd
  6. pewter s15 - as above
  7. black 180 - ballarat rd near ring rd on ramp going towards caroline springs direction
  8. silver (?) 300zx followed by blue wrx - turning right into cairn lea dve
:P ohh, so many :woot:
