Wow what a night for spotting !.
Silver r34 on Burke rd at 9pm
Black r34 sedan on high st 9.05 (I tooted)
Silver r33? Then black r32 (with sau stickers) then
White r33 gtr with blue racing stipes
All on kings way between 9.15 and 9:25pm
If I didn't get spotted tonight I don't thing I ever will lol
Spotted two bayside blue R34 GTR's yesterday, one on Chapel St, and one in Port Melbourne, as well as a black R35 GTR (BIO*** - I think he may be a resident around here).
Also spotted a nice white R34 GTR on Beach Rd this afternoon :)
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
