CR33M; was that you last night corner of Hammond & Cheltenham Rds around 11:30? Didn't get a good look at the plates, saw it the last second. Nice car though, I was going past the opposite direction in the V36, don't think you would of noticed me.
I saw N1SMO or NI5MO or N15MO or whatever on mcintyre road. (the dude with the 4door with nismo wing ect) 2pm today.
Shweeeeeeeeeeeeeet. :D
Only saw a glimpse of it but recognised it straight away.
Edited by NguyenIMPROVED
Saw cr33m around 2am on princes
HAHA! thats me dude! Suprised u "recognised it straight away". And with the number plate, close enough its 'NI2MO'
I didnt notice any skylines around there and then, Did u drive a skyline or some other car?
Was being invisible with a corolla as a passenger. Heading the other way for some yumcha @ golden leaf. :P
edit, haha, When I saw it, I was like, hmm a 4 door with black wheels, *sees nismo wing* HEY ITS NI2MO! :P
Yeap that was me both times :)
silver v35 on the monash inbound just b4 heatherton, silver r33 just after the monash divides into the gippy fwy. both had sau stickers. there was also a mnp r34 gtr about 25 min ahead of you inbound. i was outbound.
silver i thing v35 plates THIRTY 5 or similar on pound rd round 3.30pm
Also spotted JNR-ZAN again on plenty road near the Bundoora shops. Seen him a couple of times around the northside.
What car were you in?
Im around there all the time :thumbsup:
Edited by JNRZAN
I was in my white s2 r33 with black rims. Was turning into plenty rd from bent st (I think that's the name, where ray white real estate is) nd you were turning off plenty into bent! Don't think you saw me though haha.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
