CR33M; was that you last night corner of Hammond & Cheltenham Rds around 11:30? Didn't get a good look at the plates, saw it the last second. Nice car though, I was going past the opposite direction in the V36, don't think you would of noticed me.
I saw N1SMO or NI5MO or N15MO or whatever on mcintyre road. (the dude with the 4door with nismo wing ect) 2pm today.
Shweeeeeeeeeeeeeet. :D
Only saw a glimpse of it but recognised it straight away.
Edited by NguyenIMPROVED
Saw cr33m around 2am on princes
HAHA! thats me dude! Suprised u "recognised it straight away". And with the number plate, close enough its 'NI2MO'
I didnt notice any skylines around there and then, Did u drive a skyline or some other car?
Was being invisible with a corolla as a passenger. Heading the other way for some yumcha @ golden leaf. :P
edit, haha, When I saw it, I was like, hmm a 4 door with black wheels, *sees nismo wing* HEY ITS NI2MO! :P
Yeap that was me both times :)
silver v35 on the monash inbound just b4 heatherton, silver r33 just after the monash divides into the gippy fwy. both had sau stickers. there was also a mnp r34 gtr about 25 min ahead of you inbound. i was outbound.
silver i thing v35 plates THIRTY 5 or similar on pound rd round 3.30pm
Also spotted JNR-ZAN again on plenty road near the Bundoora shops. Seen him a couple of times around the northside.
What car were you in?
Im around there all the time :thumbsup:
Edited by JNRZAN
I was in my white s2 r33 with black rims. Was turning into plenty rd from bent st (I think that's the name, where ray white real estate is) nd you were turning off plenty into bent! Don't think you saw me though haha.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
