CR33M; was that you last night corner of Hammond & Cheltenham Rds around 11:30? Didn't get a good look at the plates, saw it the last second. Nice car though, I was going past the opposite direction in the V36, don't think you would of noticed me.
I saw N1SMO or NI5MO or N15MO or whatever on mcintyre road. (the dude with the 4door with nismo wing ect) 2pm today.
Shweeeeeeeeeeeeeet. :D
Only saw a glimpse of it but recognised it straight away.
Edited by NguyenIMPROVED
Saw cr33m around 2am on princes
HAHA! thats me dude! Suprised u "recognised it straight away". And with the number plate, close enough its 'NI2MO'
I didnt notice any skylines around there and then, Did u drive a skyline or some other car?
Was being invisible with a corolla as a passenger. Heading the other way for some yumcha @ golden leaf. :P
edit, haha, When I saw it, I was like, hmm a 4 door with black wheels, *sees nismo wing* HEY ITS NI2MO! :P
Yeap that was me both times :)
silver v35 on the monash inbound just b4 heatherton, silver r33 just after the monash divides into the gippy fwy. both had sau stickers. there was also a mnp r34 gtr about 25 min ahead of you inbound. i was outbound.
silver i thing v35 plates THIRTY 5 or similar on pound rd round 3.30pm
Also spotted JNR-ZAN again on plenty road near the Bundoora shops. Seen him a couple of times around the northside.
What car were you in?
Im around there all the time :thumbsup:
Edited by JNRZAN
I was in my white s2 r33 with black rims. Was turning into plenty rd from bent st (I think that's the name, where ray white real estate is) nd you were turning off plenty into bent! Don't think you saw me though haha.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
