Saw cr33m around 2am on princes
Ya i was around him...saw you flyin past in the service lane next to shell near westal rd on prinny...sounded NICE!!!!!!!!!!!!!!! :thumbsup:
Saw vspect on Friday night on chapel.
Also saw typem twice yesterday around the Croydon area
:action-smiley-069: .... saw me driving or my car parked?
Saw BASTI too there...well he saw my car parked and then called me and then saw him drive past... :D
Saw vspect pulling on to prinny highway friday arvo i think it was.
would have been me on the way to chaddy...:P
Saw Kamikazeninja taking her car off a tow truck this morning. Is it back on the road yet?
was going away to be assessed. Eta approx 1-2 months before she's back on the road 100% better... And with a few more kws... Than she was before.
Spotted a white r34 2 door in Cambwerwell 2day around 12:30 - 1pm.
Guy driver, kinda reminded me of Tom Cruise from top gun with those sunnies.. :)
Turned out of the laneway near the Salvo's, on to Riversdale rd.
Spotted Silver R34 again out the front of sharp panel paint on highbury, i assume must work there.
See silver r33 every second day on highbury rd with a big IC, think it's the same one i see at world vision australia.
Guy always has a baseball cap on.
Yellow r34 on batesford rd camberwell/burwood, does it eva get driven????
The other day on Middleborough rd, spotted a silver s1 stag, chick driver, gave a flash of headlights, no response.
Spotted a suuuuper clean and very shiny Red R32 Coupe with Bronze look-a-like LMGT4 rims. On Wellinton Parade as I was taking the train into the city. Then AGAIN! On William Street as a was walking from Flagstaff to my work lol. *Stalk*
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
