I'll probs be up there with a few of my mates spectating. There's a few cars i wouldn't mind seeing rip up winton.
I'll be there too, not sure if i'll drive up or catch a ride. Keep an eye out for a burgandy r32 and a white onevia with stickerbombed roof. i'll be in one of those cars.
Spotted a bayside blue R34 GTR cruising down North Road at about 3:00pm today. right near safeway petrol station in Huntingdale.
also spotted a Gun metal grey R32 GTR cruising down North road near Warrigal around 3:10pm, number plates Godzilllla.
Both looked hot..
Well I am now! LOL
Will be in Japan for 2 weeks in November. Hoping to get Import Monster to find a few clean 32R's for me so I can look at them while I'm there, then get him to bring one in for me :)
The exchange ain't looking too good atm though, hopefully things pick up between now and then.
According to your sig, you're still running stock turbos. Planning to upgrade at all?
Interesting, I hope u gonna keep ur civic; you know im a big fan.
Im gonna put in some 2860-9 turbz, bought some 2530's a little while ago but sold them cos i dont like lag and am happy with 250ish awkw.
Even though, only gonna run 1bar max as its enough power - trust me.
PM me if you wanna chat about gtr's
I'll be driving up there in my 34, probs have a supra or two and maybe a 33 in tow as well.
I'm thinking a nice detour through reefton spur :)
I only go through the spur when its nice weather. Going home in the rain after no sleep through the spur is not fun lol
lol... when we parked I didn't see any :P
must've been there bright n early haha
i found a parking spot out the front, and there was a silver 32R that was behind me, but i got it first.
when i got out, i realised if i had moved closer to the r34 in front, he probably could have JUST fit. sorry dude
