Like Eye Candy? Lmao oh lawd, is this the new cr33m...
LOL!!!
Krys is a hard flamin mongrel bro. I'd stay away from him and his Wala hektik boxing bro
Haha, nah he will get his brother onto you. Because we all need other people to fight our battles :P
Silver 34 GTT on Bwd Hwy heading towards Knox maybe around 9:30ish... Had one of those too big factory spoilers (:P), and a play just before I turned off on mountain hwy, heard the turbo spooling up, sounded tough!
I was in black 34, ijelly.
LOL!!!
I met him and his brother, I'm pretty sure my leg is taller than both of them standing on top of eachother hahahaha
