Yesterday at Willowbank Raceway Mark Jacobsen piloted the R32 further into the record books with a 8.271 @ 171 MPH to set a new record, narrowly beat the old Croydon Racing mark of 8.273. The pass was done "off the trailer" at the meet and he tells me that with further suspension improvements and a little more power the car should be capable of a high 7 sec pass.
congrats to Mark and his team for the awesome result.
thanks guys . we are very happy we ran that pass about 2 in the arvo was quite hot and had a fair bit of wheel spin off the line....
our other passes one run bogged of the line and ran 8.4 at 169.98 with a 1.47 60ft at 5.30 in the arvo with better air .
then our final run was at 7.30pm but we crossed the centre line in 2nd gear so aborted the run.... just need to get the rear suspension sorted and it will be great..
cheers, mark
well done. makes me happy to see people still doing serious development with the ol' R32. Maybe you can have that elusive 7 in time for the R32s 20th birthday? :nyaanyaa:
The other, slower, aborted passes were more telling of the car's potential and I reckon it'll be sooner rather than later that the car sees teens, oh's and then high sevens.
