  • Replies 55
Just got back from my nose around of the GTR....looks good :D Shame it only comes out of it's box for a couple of perfomances later in the day :ninja:
However don't mention "grey imports", even though the girls look cute & innocent they've been brainwashed by Colin Buckley and will turn on you in seconds like fembots!!!!
Apparently Nissan thinks it's OK to import R34's as they ever wanted them anyway (hahaha) but don't think about the 35 or they'll get you LOL!!!!
I asked if they were doing similar things to the UK and offering better spec equipment over the "grey imports" to sway buyers.....errr no they're not, you may even get a lower spec version for more cost...wtf?
https://www.sau.com.au/forums/topic/210719-gtr-r35/page/2/#findComment-3746141
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
