  • Replies 1.9k
I think a rotary would be even harder for the die-hard Nissan enthusiasts to stomach than the Chev.
Chev is easier to fit too... but the 20B would be awesome. I contemplated this too, but in my 180 :P
Both are pretty much hated :D
I used to own a few rotaries, and now have a nissan and an LS1. I just can't make up my mind! ;)
I would love to have a rotary for a race car!! It's on the list to own one day :) or is that a bucket list :P
:blink:
i thought you would like it john ! they are fantastic
please dont tell your time .... you probably went faster in the wet than me in the dry!! lol
actually would be really cool to see how fast you could punt one around oran !! i reckon high 1.15 with no mercy! which would be awsome !
Hehe we are going to organise for another time to have a drive in the dry. I will keep you posted. There computer upgrade gives it another 70kwatw :huh: 290+ standard and 360+ with the Haltech :blink:
see video of R33 GTSt with a 20B in it...
Also 350Z with 20B...
I would go V8 rather than rotary... swore to myself that if I destroyed the RB again it would be Nissan V8 time... with a big SC:)
I don't even need to click the first link to know that it's Pete's burgundy R33. It's a cammy RB and not a rotary - although it fooled a heap of people who watched the video.
***EDIT***
Farkin' LOL at the Youtube comments! Holy crap!
Haha speaking of engine conversions I was really considering at one stage to put an rb25 in the rx :thumbsup:
LOL...NO!!!!!!!!!!!!!!!!!!!! If that is your car in your post then keep the rotor in it. (oh and looks like a great FC by the way :thumbsup: )
RBs are big , heavy and lazy things, which work well in a Skyline...but. Hell i would say throw a V8 in the FC before an RB :)
I am holding out for R35 GTR V spec, just need sponsor or something or another minor miracle.
What about this car for track weapon? How about a 4wd carbon body, custom V8 with 2 x Hayabusa heads, dry sump, 420hp and only 500kg, awesome aero and very low height and centre fo gravity. Illegal for Superlap though.
Track Beast
they use chain drive from memory. :thumbsup: and it's a fairly light spaceframe, with super light body. and they use tiny very light diffs and I think inboard brakes too from memory.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
