  • Replies 245
Posted Images
consider youselves lucky
im an electrician. does not matter how much i earn as it all goes to my girlfriend anyways! :P
I know someone else that would say that too. :P
I work for my Grandparents as an admin assisitant, best job ever.
Lukes a fitter/machinest slash CNC programer aka Mechanical Engineer.
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775362
Grog ofcourse :)
my garage is full of past used by date beer if that helps
I wish i had a spare million for a cnc machine. Just think of the rediculous things i could make
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775644
I make the holes in the middle of dohnuts. good pay but very high pressure job to get it just right. I also do muffin stump removal like newman and previously worked as a mercenary during gulf war 1, gulf war 2 and gulf war 3 "payback". follow your dreams!
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775658
I'm a software engineer / web developer (what a shock!!) for realestate.com.au.
Christian
# Give agents more then 26 upload options for photo's.
# For the love of god, write a tech article for idiot agents on how to resize images. Alot still manage to upload pixilated photo’s.
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775810
Tell me about it! I used to get so annoyed with that website! Although not as bad as justlisted.com.au
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775829
tell them i'm sick of paying for advertising on there. make it free for me prankeh! I need to advertise my place this week. :)
cutting the holes out of doughnuts for a crust has not exactly left me rolling in dough... ahhh nuts!, pun overload!
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775914
LOL...
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775998
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
