hi guys, its about my R34 headlights
i got this yellowish mark inside my headlight, well i dont quite know how to explain it but you guys probably know anyway the good old mark in old car headlight..
question is simple how to get rid off it?? :P
I want it to be nice clear and shiny, i asked a guy who sells HIDs but he said if he opened it up, polish it, and close it again, it wouldnt be perfect and when rain comes, some water vapour will get inside and shit and leaves water marks..
cheers
https://www.sau.com.au/forums/topic/215569-cleaning-headlights/
This has been covered many times before mate. Next time do a search, but you can just use and polish to remove the yellow cover depending on how bad it is. If something like Maguires Scratch X doesn't work then you'll have to open up the head light. To do that, you'll need to put the headlight in your oven to melt the glue, open, clean, etc.
The reason the HID guy told you it won't be perfect is because most people don't buy new seals, they just re-heat and stick the cover back on. If you got new glue to seal it up, it should be like new.
just use some cut and polish . kitten works well , then use something smoother . buff it well with heaps of elbow grease. i sanded my headlights right back from 400 gritt all the way to 2000 gritt . they turned out un believable. i also did it to a friends car , and the sprayed his headlights with clear gloss and they havent got yellow ever since. perfection
:D:(:) guys, c-red actually polished my headlights when i did my 10k service, he uses some kind of japanese plastic cleaner... :D GO JAPANESE!!
works excellent, was very happy, and the guy said u can get similar plastic cleaner from super cheap auto, so im gonna do that the next time its need a clean!!
thx for the reply anyway, prob solved :D
eyy buddy their is this stuff that looks like cut and polish, but you just rub it on the headlights and it gets rid of all that shit... my mate showed me it i can get you the name of it if you like. but it does a bloody good job lol
Permatex, Headlight restoration kit. This involves wet sanding your lights with a fine wet dry in 3 stages. then using the plastic polish supplied in the kit to finish it off. 30 bucks a kit does 2 lights easily. I have used it and it goes awesome.
If you have mad yellow lights you just sand more. you see it all come off in the water you sand with. then the polish smooths the scratches and your lenses are clear again.
I know Autobarn stock this. But i suppose anyone who stocks permatex can too!
