  • Replies 151
Ladies and gentlemen, sorry for the wait - my thanks to PranK for raising some interest in my little project here.
Without further ado, I present to you, pictures of the camera mount:
I don't have any pictures of it set up in a car, perhaps PranK will provide some later, but these photos should give you a fair idea how things work. Typically, you'll have the suction cup attached to your rear window, and the camera standing on your rear parcel shelf supported by the tripod. So, your camera will see something like this:
Initially I only made a few of these for friends like PranK, but seeing the interest shown here, I am prepared to do a 'production run'. My price to PranK was 'mate's rates' and not including the mini tripod, so price including tripod will be $80 each, less if I get plenty of orders, seeing as how this is a group buy. If you would like one, please email me (blahboy -at- iinet.net.au) so I can prepare accordingly. Cheers!
I've just gone through this thread and realised how long ago it was started - apologies to the people who were hanging out for this, PranK didn't really let on the full extent of what was happening.
If all of the people who said they were interested still are, then please, let me know now, I think the price will be closer to $70. I also noticed in the forum rules I'm not supposed to ask people to post expressions of interest... so I guess I'm sort of taking orders. Please either post here again if you want one or email me, or send a PM.
ill take one without tri pod as ive got the little tripod thingy already, $60 ??? u would be able to stick it on like the front window as well hey ???
Clint
You can put it at the front of the car no problem.
$60 sans tripod could be achievable, it's entirely dependant on numbers. Reason is that I can source the suction cup cheaply from a wholesaler, but there is a minimum order quantity. Otherwise, if I get them retail, it will be about twice as expensive, plus each unit carries a larger burden of shipping. So if you're interested but concerned about price, step forward, and I'll work things as best I can.
is the camera hard to install?  where does it go?
The whole thing is really easy to set up, all consumer still and video cameras have a thread on the bottom that is standard sized, which attaches to the thread on the mount.
I'm afraid I still don't have any photos of it set up in a car, so here's an embarassingly cheesy sketch done by me in MS Paint in an attempt to explain:
Obviously, the drawing is rough, but hopefully you get the idea. Depending on the car, the mount might be set up with the camera towards the rear glass rather than away, and if there's a real lack of room back there, then you would omit the tripod and sit the base of the camera mount directly on the rear parcel shelf. Leaving the camera hanging isn't recommended as you don't get a steady picture. Hope this helps!
i gotta say - that drawing is pretty dodgy, but also very clear.
Um, thanks? :D
thanx for that drawing cos it makes sense to me now of how it works.
my friend maybe very interested. r the final details finalised yet?
There aren't that many details - if you'd like one, you let me know. Best guess, will be $70 for the package.
Bugger it, I'll take one! I've got a great mount attached to my rollcage in the mini, and was thinking of getting one made up that mounts between the rear passenger grab rails (like the custom made WRX Club ones for WRXs). It hangs the camera right in the middle of the car... but this suction cup version is available so I might as well grab it!
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
