  • Replies 151
Just wated to say thanks for sending off the mount today! I know you went thru alot of crap at the post office over a crappy postage frank stamp!
Hopefully there aint going to be no more probs getting to my work ;-)
I seriously didnt see a prob tho as this isnt the first time I have sent something off like this?!
Thanks again!
OK Erik, just for you, my dodgy sketch again! :)
You can use it at the front of the car, on the front windscreen, or at the back with the rear windscreen. You use the mini tripod if you need to raise the camera off whatever surface is underneath.
For best results, put some tension into the system so that the camera mount is really snug, being pressed down by the windscreen and pushed up by whatever's underneath it - all tightened up so that the camera isn't jumping around.
Hope that helps. Perhaps if people take some photos with the camera mount set up in their cars?
Erik,
Are you using the lever on the side of the mount? It is 'unlocked' when the lever is loose, and you swing it over to lock it in place. On the side with the handle, there's a notch in the rubber skirt that should line up with the left plastic piece that juts up from the top section. Unlock the suction cup, place it firmly against any reasonably flat and non-porous surface (eg glass, metal), and swing the arm over to lock. As everyone who has witnessed this will agree, there is not a snowflake in heck of it falling off by itself.
True, but I want to be able to see my dash when on the track - I use it to examine cornering speed (I've got a mount anchored to the rollcage in my mini). I'm also going to check my 0-100km/h time :)
Also, if I have it sitting any further back (to allow tripod to sit on rear shelf) I may not have enough room to fit the digicam. I'll be playing around with it when I've got a suitable digicam anyway.
we used 2 of these all weekend in the dutton rally and only lost it 3 times in 44 runs which is pretty good considering it included airborn cars and insane dorift... :)
:D
Yeah worked a treat... but if anyone know where we can get a 40/50 cm extension for the mini tripod stand would be great... just watched the footage from the Z and talk about sea sick!!!! wowowowowoa. :spew:
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
