Thats alright man, wait til I have it all set up with some gripy tyres next time, Will be alot faster
:) yey! can't wait !!
Nah, that guy was a toss, Zane was the guy with the jumper
Oh right, i looked at him, im like dude you serious! me in my jumper + 10 shirts lol, his in a singlet mmm :D
  • Replies 344
Posted Images
Dam it i got beat on the second skidpan!!!!!!!!!!! dam missed a cone on the frist run which F%$Ked me over. Tek GTR can never lose.
Dam the back track was heaps faster in the arvo.
7&23 better be GTRs not a pesky EVO
I drove car number 7.
So this event will be held again in August ??
Tim.
Good good only R32s that beat me and bring the next one. I was 28
TURISMO thats a great time on the back track 1.44 in the morning was super fast!!
Thanks man, that's when my tyres were only bald, not delaminated
Full frame/Graig did you get any shots of my car doing a little smoke show? I really love that pic of my car on the freeway! and that you shopped the dent out of my bonnet in one of the pics LOL
Thanks again for the jack :thumbsup:
Its about time!
If you find one for like $500 thats manual let me know, ill get one aswel. Yes im serious
i got a manual wagon that i will sell as is for $500. at the mo its got cut springs and a rooted cat and rear muffler. i was gonna replace shocks and springs with peddats lowered springs and KYB shocks and fix the exaust and sell for $1500 with rego and RWC
altho it is in canberra. either way let me know if you interested
DM
Anyone who has footage or good stills and wants to contribute to the club version of the DVD, contact me ASAP via PM or email , matt AT ignitiondvd.com
wooop! :w00t::rofl::laugh:
I'll burn you a CD and hand it over at the AGM if you're there. :D
If you're not i'll give it to Adam or Sammeh to pass on. ;)
Its about time!
no one will ever get a bargain again like my first Skyline- a manual R31 GXE sedan with 9 months rego for $750 :w00t:
should have kept it...
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
