  • Replies 895
were selling for 1650
hoping to have the 1st few installed and tuned next week
i am hoping for the install THIS WEEK i have been waiting a week now and no contact about when it can be installed and tuned if it dont happen soon i will be wanting a refund.
a bit of communication would go a long way
Edited by gazza750
according to my disto features on plug in are as per v44
so antilag is option
launch control is std
You mean you have to pay more for antilag?
WTF is this shit?
It's a piece of code, they should just f**king add it!
WTF is this shit?
can someone confirm that antilag is an option? so you'd have to pay more for it? how much if so..
Just went and saw my tuner last night I am having a V88 installed on my R33 GTR.
So far has just tuned for idle and cold start and I am already impressed. Punch the throttle and it goes back to idle smoothly, sits on about 800rpm and sounds great. Software looks good too, really easy to understand.
A day or so on the dyno now and hopefully I will get it back. Excited!
Big Mike
Welcome to MOTEC
and in the blink of an eye the Autronic jumps lightyears ahead...
seriously though, paul can you confirm this?
also will they 'communicate' with the AIM dashes? like the haltech/autronic ecus do?
i might just ring mark in the morning
I've been running the Nissan plug-in ViPEC on my R32 GTR for a couple of weeks and couldn't be happier. I sold my PFC including datalogit and Nismo MAFs for a bit less than I paid for the ViPEC and my car runs much better.
I first installed my PFC on an OEM build and had absolutely no complaints. The car idled well, pulled hard, gave me all the control of fueling and ignition timing I needed. I added 264/265 x 9.7 mm cams and a set of GT2860R-5 turbos and everything was still great. Added HKS dumps, had some fairly extensive exhaust porting done and raised compression ratio to about 8.7:1 and couldn't get the PFC to control idle consistently. Part throttle shuffle was interfering with my life as well and could not be tuned out.
Slightly off topic rant. Skip unless you're interested in why MAP>MAF sometimes...
Root cause is that the MAF transfer function is nonlinear, and the PFC adds the raw voltages BEFORE it applies the transfer function. Oscillating airflow therefore appears to be oscillating load and the PFC changes fueling and spark accordingly. This feeds the shuffle and results in an unstable situation. If you could apply the transfer function to each MAF signal and THEN add them, the system wouldn't go unstable.
Back to the ViPEC... It uses the factory CAS without any drama. The tuning went very smoothly with autotune every 500 rpm on the dyno making short work of fueling tweaks. (Innovate wideband feeds an aux channel for great accuracy and response time) We only layered on one more dimension to manage the differing fuel needs for part throttle vs WOT at a given engine speed and boost level. The car pulls nicely from the basement right to redline.
The tune is pretty conservative running 10.5:1 at 17 psi in the higher rpm cells. More timing could be fed in as well, but the lack of knock control, or even indication of knock, makes me want to run conservatively until I get a handle on this. By the time you hear it from the driver's seat it's pretty bad... Don't want to go there.
Anyhow, here's what my setup looks like with the dyno numbers.
Cheers,
Dan
VEHICLE: 1989 GT-R
ENGINE: RB26DETT, 88mm bore, CR=8.7:1
MILEAGE: 127xxx Kms
OIL/WATER PUMP: Nismo/OEM
OILING SYSTEM: Tomei Orifice, Tomei pan baffle, Greddy oil cooler and filter relocation
INJECTORS: 600cc Nismo
FUEL SYSTEM: Bosche 044 in-tank
TURBO SETUP: twin GT2860R-5
MAP or MAF's: MAP
INTAKE SETUP: Apexi Power intake
INTERCOOLER: OEM
VALVETRAIN: JUN 264/264 9.7 mm lift - adjustable gears
HEAD WORK: Intake mildly ported and left rough, exhaust opened up about 15% and polished, combustion chamber polished
EXHAUST: HKS dumps, Tomei DP, 85 mm HKS Priest
BOOST LEVEL: 1.2 bar = 17 psi - Blitz Dual SBC Type R
ECU SETUP: ViPEC Speed Density
CLUTCH: ORC series 700 twin
COOLING: Greddy aluminum rad with electric fan
DYNO:
Note linear torque increase from a respectable 150 ft.lbs @ 2500 to a slingshot-like 325 ft.lbs @4300 rpm, relatively flat plateau to about 6500 rpm and only modest drop in torque up to 7500. This is without any cam timing tweaks and with everything pretty darn warm.
The car feels very alive on the road and willing to rev til you shift. :drive:
Nice conservative tune intended to let me have a ton of fun without making rebuilds my hobby.
HP: 390
TQ: 330
Edited by GTR-Dad
Gary,
Which workshop is doing the tuning?
did they quote how much it cost to tune it?
Cheers
i dropped it off to Alistair @ Autoworxs this morning he is installing the ecu and loading base map then Lumpy is tuning it on Tenagah Motorsports dyno on monday morning :( yay no more afm's to worry about
will one of these fit an stagea s1 with auto? and where in melbourne would i get it tuned?
i've been trying to get a dealership as i have a few customers wanting them but melbourne is tied up with JPC and so far i have not recieved more information.... still waiting. ;)
i've been trying to get a dealership as i have a few customers wanting them but melbourne is tied up with JPC and so far i have not recieved more information.... still waiting. :P
Thats awesome but my problem is i still need to know if this thing is gonna work with my auto, if it will i will be your first stagea customer
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
