  • Replies 895
were selling for 1650
hoping to have the 1st few installed and tuned next week
i am hoping for the install THIS WEEK i have been waiting a week now and no contact about when it can be installed and tuned if it dont happen soon i will be wanting a refund.
a bit of communication would go a long way
Edited by gazza750
according to my disto features on plug in are as per v44
so antilag is option
launch control is std
You mean you have to pay more for antilag?
WTF is this shit?
It's a piece of code, they should just f**king add it!
WTF is this shit?
can someone confirm that antilag is an option? so you'd have to pay more for it? how much if so..
Just went and saw my tuner last night I am having a V88 installed on my R33 GTR.
So far has just tuned for idle and cold start and I am already impressed. Punch the throttle and it goes back to idle smoothly, sits on about 800rpm and sounds great. Software looks good too, really easy to understand.
A day or so on the dyno now and hopefully I will get it back. Excited!
Big Mike
Welcome to MOTEC
and in the blink of an eye the Autronic jumps lightyears ahead...
seriously though, paul can you confirm this?
also will they 'communicate' with the AIM dashes? like the haltech/autronic ecus do?
i might just ring mark in the morning
I've been running the Nissan plug-in ViPEC on my R32 GTR for a couple of weeks and couldn't be happier. I sold my PFC including datalogit and Nismo MAFs for a bit less than I paid for the ViPEC and my car runs much better.
I first installed my PFC on an OEM build and had absolutely no complaints. The car idled well, pulled hard, gave me all the control of fueling and ignition timing I needed. I added 264/265 x 9.7 mm cams and a set of GT2860R-5 turbos and everything was still great. Added HKS dumps, had some fairly extensive exhaust porting done and raised compression ratio to about 8.7:1 and couldn't get the PFC to control idle consistently. Part throttle shuffle was interfering with my life as well and could not be tuned out.
Slightly off topic rant. Skip unless you're interested in why MAP>MAF sometimes...
Root cause is that the MAF transfer function is nonlinear, and the PFC adds the raw voltages BEFORE it applies the transfer function. Oscillating airflow therefore appears to be oscillating load and the PFC changes fueling and spark accordingly. This feeds the shuffle and results in an unstable situation. If you could apply the transfer function to each MAF signal and THEN add them, the system wouldn't go unstable.
Back to the ViPEC... It uses the factory CAS without any drama. The tuning went very smoothly with autotune every 500 rpm on the dyno making short work of fueling tweaks. (Innovate wideband feeds an aux channel for great accuracy and response time) We only layered on one more dimension to manage the differing fuel needs for part throttle vs WOT at a given engine speed and boost level. The car pulls nicely from the basement right to redline.
The tune is pretty conservative running 10.5:1 at 17 psi in the higher rpm cells. More timing could be fed in as well, but the lack of knock control, or even indication of knock, makes me want to run conservatively until I get a handle on this. By the time you hear it from the driver's seat it's pretty bad... Don't want to go there.
Anyhow, here's what my setup looks like with the dyno numbers.
Cheers,
Dan
VEHICLE: 1989 GT-R
ENGINE: RB26DETT, 88mm bore, CR=8.7:1
MILEAGE: 127xxx Kms
OIL/WATER PUMP: Nismo/OEM
OILING SYSTEM: Tomei Orifice, Tomei pan baffle, Greddy oil cooler and filter relocation
INJECTORS: 600cc Nismo
FUEL SYSTEM: Bosche 044 in-tank
TURBO SETUP: twin GT2860R-5
MAP or MAF's: MAP
INTAKE SETUP: Apexi Power intake
INTERCOOLER: OEM
VALVETRAIN: JUN 264/264 9.7 mm lift - adjustable gears
HEAD WORK: Intake mildly ported and left rough, exhaust opened up about 15% and polished, combustion chamber polished
EXHAUST: HKS dumps, Tomei DP, 85 mm HKS Priest
BOOST LEVEL: 1.2 bar = 17 psi - Blitz Dual SBC Type R
ECU SETUP: ViPEC Speed Density
CLUTCH: ORC series 700 twin
COOLING: Greddy aluminum rad with electric fan
DYNO:
Note linear torque increase from a respectable 150 ft.lbs @ 2500 to a slingshot-like 325 ft.lbs @4300 rpm, relatively flat plateau to about 6500 rpm and only modest drop in torque up to 7500. This is without any cam timing tweaks and with everything pretty darn warm.
The car feels very alive on the road and willing to rev til you shift. :drive:
Nice conservative tune intended to let me have a ton of fun without making rebuilds my hobby.
HP: 390
TQ: 330
Edited by GTR-Dad
Gary,
Which workshop is doing the tuning?
did they quote how much it cost to tune it?
Cheers
i dropped it off to Alistair @ Autoworxs this morning he is installing the ecu and loading base map then Lumpy is tuning it on Tenagah Motorsports dyno on monday morning :( yay no more afm's to worry about
will one of these fit an stagea s1 with auto? and where in melbourne would i get it tuned?
i've been trying to get a dealership as i have a few customers wanting them but melbourne is tied up with JPC and so far i have not recieved more information.... still waiting. ;)
i've been trying to get a dealership as i have a few customers wanting them but melbourne is tied up with JPC and so far i have not recieved more information.... still waiting. :P
Thats awesome but my problem is i still need to know if this thing is gonna work with my auto, if it will i will be your first stagea customer
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
