I am still curious for clarification on the V66 Skyline plug in model.
There are so many stories going around about if it even exists or not and what specs it is.
I was originally told that the V44 had 4 ignition outputs so a wasted spark set up was used on 6 cylinder cars, the V88 had 8 outputs so two were not utilised. To overcome this a cut down version of the V88 was produced for the Skyline Model that had 6 outputs. This sounded fair, till I started asking around and got differing stories from different suppliers. So, I went straight to the company themselves and all they could do was to point me to the link on their website which didn't tell me anything until I downloaded the manual for the Skyline Version and it appears that it is a V44 with connectors already attached for the Skyline loom.
So if anybody can 100% definitively answer this question I would like to know.
I will probably still end up purchasing one of these in the next month or so for the GTR once my other car has been sold but I to would simply like a straight answer to a simple question.
  • Replies 895
Inside the box, the design is quite clever. It looks like they have a standard board which has the processor etc on it. This then plugs into a base board, which is designed for the particular car and is the correct size to fit in the case and has the standard loom connector on it. So I suspect the processor board is a V44 and the base board has the extra circuitry for the six injector outputs.
I've had my Vipec for 3 weeks now and it seems to be working faultlessly. This morning I started it up, it started first time and held the revs perfectly. Far better than the stock ECU, which was having problems controlling the idle in my car.
Getting mine installed next week.
i got a plugin installed on my 33 series 2 gtst by Mark @ godzilla. made 245rwhp with stock injectors and turbo @ 13psi (i got fuel pump and regulator, hybrid fmic, pod, dump + highflo cat)
but it runs really smooth, a lot more responsive than it was with the stock ecu
should be good when i round up some more $$$ for turbo and injectors and splitfires
or because link do the manufacturing for them and already had that casing designed it was cheaper to just use it than design a new one?
can you name the benefits over a G4? im yet to see anyone prove its any differrent? either way they are great units (vipec and G4) and better than a certain very popular sydney produced product in my experience.
For anyone installing one of these the intake temp sensor thread is a 1/8" 8NPT with 27 threads per inch.
Trent, from what i could see on the link website they don't offer any plugin models of the G4?
Edited by TiTAN
can someone post a pic of the link g4 board ?
my understanding is they are indeed different , hardware , logic , firmware etc . vipec is manufactured by link and looks like it does use same case but beyond that would be nice to confirm.
either way product is great , if link g4 is as good , even better another great option
have one in my personal gtr now and even with a quick rough 1hr tune starts and idles better than factory
plug in is v44 with extra injector drivers , not v88 cut down . im pretty sure its covered in this thread a few times but at 20 pages its hard to find specifics now
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
