BTW I just wanted to clarify something from earlier in the thread.
Choices made during tuning won't give you more responsive motor, or at least there is no compromise to be made between power and response in tuning. The tuner is either making all available power at a given load cell or they are not, the only option is less timing or more fuel which are safety margins - they won't increase response.
Any gain in the response is in the mechanical setup, not the tune.
Smaller turbo
Lighter turbo rotating mass
More capacity
Shorter intake
Smaller Cams
Cam timing
Smaller, shorter exhaust manifold
Free flowing exhaust
Smaller intercooler
Holding wastegate fully shut until it opens
  • Like 3
Smaller turbo
More capacity
Shorter intake
Smaller Cams
Cam timing
Smaller intercooler
Holding wastegate fully shut until it needs to open
exactly !!!
it's more the way the cams are set, making better use of the air it gets meaning the turbos don't have to working as had
a good quality boost controller doesn't hurt either
what mods have you got done ?, cause yeah that's not great at all, what boost is that ?
cam gears ? if not get some
It has a bosch fuel pump, -5's, came with the car, so i got tomei cam gears, Tomei poncams(gotta confirm which one i'm receiving), Valve springs, ARP head studs and on the hunt for decent priced nismo AFM, then hopefully a good tune at JEM. Hopefully looks better than the last tune.
I got told I was running 18psi cuz he didn't want to go any further incase he blows a head gasket. Not knowing much I just said ok o_0any ideas what might be wrong? Sorry,I have no clue haha
What exhaust have you got ?
If you are after response you want stock cams or type R 250 Poncams and have them dialed in for response, I have settings for most cams, anything bigger in the poncam range will lose you response
-5s on 18psi should be making a lot more then that even on a stock motor providing it can breath
Save your money on the Nismo AFMs and put it towards a good computer that uses map
HKS hi power silent, i want the amuse r1 thats for sale but old man doesn't like a loud car =[, its got a pfc, and it has stock cams in it at the moment. Previous owner had cams listed on ad as well, but wasn't informed what cams i was running, so could it be possible that i might have cams not suited for response or not dialed in for response? but either way, when i get new cams put in, i'll see what my old cams were, see if they were stock or aftermarket.
Thanks for the post Duncan. As for as your list goes, there's a couple of things here I am curious about:
Smaller turbo - I'm assuming -7's are the 'smallest' turbo one can buy, since ceramics go pop at the race track.
Lighter turbo rotating mass - as above
More capacity - It's going to have to make do for now
Smaller Cams - smaller than factory?
Free flowing exhaust - I have sidepipes, not sure about the manifold though
Smaller intercooler - I'm assuming there's no use in going smaller than factory?
Holding wastegate fully shut until it opens - I'm still using standard wastegate. Is there any reason to switch to something else?
Cheers
What front pipe and cat have you got ?
Can you contact the old owner and see if you can find out what cams are in it, I know if I got some cams in then payed a workshop to change and found out I put in exactly what I pulled out I'd be pissed, and that is a clean and clear waste of money
Smaller turbo
More capacity
Shorter intake
Smaller Cams
Cam timing
Smaller intercooler
This....i hate hearing "i tuned it for response bro, not top end".... makes me want to slap people.
The funny thing is the owner i bought it off bought it off another guy who said he had done it all at Croydon race dev, so the owner i bought it off has no clue lol, so what im thinking is when i come to installing my new parts, and the old parts come out, i'm going to make a record of what comes out =\ as for the front pipe, i have to double check what is there, i don't remember what it was when it was inspected by mechanic before i bought the car xD not a very good memory =[
Haha yeah right, I say my car was tuned for response and what I mean by it is I have chosen all the parts on my car for response and dialed in the cams to give better low which helps the responsiveness of the turbos, which is a form of tuning
So saying you have turned the cams in a way which promotes more low end twist at the sacrifice of top end power (say it rolls over at 7500 instead of 8500-8800) means nothing?
That does make helping harder, where are you located
What you might have to do is rip off one of the cam covers and get the part number off the end of the cam cause if their not poncams but full aftermarket then poncams may not be "boltin" any more in which case you may as well go the 260 x 10.8 procam or better yet the unigroup cams
No no no, not talking about anything mechanical. People go in with a car that has boltons and say the ECU was tuned for response....no camgears, cams, etc.
fyp
Lol. Was meant to say 300hp.
I don't see what all the fuss is.
Its proven that 7's with cam gears 20 pound of the boost is responsive and puts out a nice linear power delivery
Or if you don't car about power and just super response then you should have bought something else.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
