There is, well not so much before and after more just different setups and their result in the Forced Performance Thread home page at the top there are dyno result threads
http://www.skylinesaustralia.com/forums/topic/104332-rb30-hybrid-upgrade-all-dyno-results/
http://www.skylinesaustralia.com/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/
This are the two most relevant for you
Thanks Mick I will have a look when I get home.
Took Scottys advice and started a new post for Strokers and see what happens
Haha, car is slowly getting there, nothing new from last dyno results, got myself some nismo AFM, and about to purchase a set of new o2 sensors, and recently acquired a ARC cooling panel too, nothing fancy pants in power division lately xD and maybe looking at getting hard pipe kit soon,and helping dad with his 32gtr
Tbh, he said he was expecting around that because of the restrictions of my standard AFMs, so yea....when i install my next parts gonna go different tuner, my last tune was at JEM, and might see what other people suggest to go, when i'm ready that is xD colelct more parts first, hehe.
The NISMO RB26DETT Engine Parts - Air Flow Meter is a direct, easy and a popular upgrade on RB26DETT engines as they are the same dimensions as the stock units. This is a popular and necessary upgrade for engines making serious HP! You will need 2 in order to replace your MAF system. These NISMO units can flow a max of 2400kg/h of air and support 775ps max power whereas the stock ones can only flow 1400kg/h of air and support 450ps max power.
Taken from RHDjapan xD
Nice cut and post but I already know about them
So in the same sentence they say they are the same dimensions as stock but can flow nearly twice the amount of air
Just saying they are both 65mm AFMs so IF air flow is a restriction then replacing it with another 65mm AFM isn't really going to help you, if its tuning resolution that is restricting and NOT flow then sure go for the Nismos, they only twice the price as Z32s and flow less :thumbsup:
Edit: and with less tuning resolution
  • Like 1
ahh, thanks for the info, so did i just waste money buying NISMO ones then? o_0 but as people said before, air restriction shouldn't be an issue as in previous posts people have said that my OEM AFM should be fine even if i've changed turbos and the mods i have now o_0 so now i'm abit worried as to if there's something else wrong with my engine or it was just the tune =\
Tuners are usually suspect of old engines and unknown builds. They don't always trust a setup to lean on them hard, especially the first time they tune them. They don't want to blow your engine, it makes them look bad.
Sometimes all it takes is fitting an exhaust temp gauge, or telling them you have a spare engine to go in, that way they aren't so scared to turn up the wick. E85 should take most of their worries away. ;)
If the workshop and tuner is worth half a grain of salt, they will have a scope to checkout the pistons if they are forged and a good set of knock sensors to read whats happening while tuning.
If they see stock pistons they should know what time of day it is.....
Is it in the projects section? If it is, a couple days sometimes.
Hi , It is Pete , I am away from my PC and cannot answer as TT350GT.
I have asked Jim to quote on the Quaife diff and we will go from there.
Just drove up the coast to Port Macquarie , great day for a drive and even with the last mods it was fun.
Lucky though , as I stick to the speed limit but the bloke in front got knocked off for 20 over , lucky me :)
why would they go looking for forged pistons? tuners aren't going to waste time doing that......they don't need to if they have the right tools to tune the car properly.
Edited by Badgaz
Because thats what professional workshops do when a unknown engine rolls up and the customer asks for a zillion Kw.
They pull the plugs, get a bore scope out and checkout the condition and whats inside.
Without knowing if the bottom end is built, would you lay into it?
Knock sensors can only tell you so much, a pulled ring land can happen without much knock on a stock piston.
Edited by GTRPSI
  • Like 1
hmm i just think i'd never expect a tuner to do these things....after all you take a car to a tuner to set the tune for your modifications...if you don't even know what those modifications are then you can be wasting your time...but in the same token the tuner doesn't need to know when tuning because he/she will find the limitations with the tools they use. e.g knock limited engine. Most of the time tuners usually end up telling customers to go and buy/replace stuff that they find is the restriction limiting there performance potential....hence probably why he suggested the AFM's in this case.
There's a big difference between tuning a car making 200rwkw and 400rwkw
I would expect the tuner if they want to maintain a professional image would approach things differently.
And keep in mind the tuner isn't actually wasting their time. They get paid for their time.
  • Like 1
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
