engine mods which have been done are
HKS step1 camshafts 264/264
HKS adjustable camgears
HKS inlet manifold gasket
Gates timing belt
custom stainless billet CNC machined oil pump
R33 RB26 crank shaft
external oil return lines from cylinder head to sump
Garrett GT35R Ball Bearing turbo with .78 divided exhaust housing
TiAL 44mm external wastegate
screamer pipe
custom twin scroll steampipe Manifold
custom dump pipe + front pipe
hi flow 3inch cat
X force cat back exhaust system
115mm intercooler
custom aluminum intercooler piping
custom intake pipe
custom air box
greddy blow of valve
custom catch can
aluminum radiator
SARD fuel reg
SARD 800cc injectors
Bosch 023 fuel pump
Power FC D jetro
HKS triple plate clutch
316kw @ 16psi
had some problems with the ignition system causing the engine to miss fire so we were unable to run any more boost
tuner reckons there is abit more power to be made once the ignition system gets upgrade
let me know wat u think
Edited by STR8E180
https://www.sau.com.au/forums/topic/220278-dyno-results/
  • Replies 67
thats a bit low for a GT35?
I made 314rwkw on 18psi with a GT3037, 0.63 rear housing. Standard RB25 engine, no mods. Was done on a mainline and dynodynamics too, and I made sure nothing was fudged.
Are you using a 0.7 compressor cover? If so, get it up to 22psi :)
https://www.sau.com.au/forums/topic/220278-dyno-results/#findComment-3884393
Good result, however i would expect a bit more,
like i said B4 we had into problems with miss firing due to ignition problems
200 killerwasps at 5000rpm! and full boost (well near enoug) at just over 4k I Like :)
What sort of boost pressure do you plan on running once spark issues are sorted?
i dont plan on running a set amount of boost im just gonna upgrade the ignition system and hand the car back over to my tuner
basically just told him keep tunning untill u run into problems (which is wat he did), once it starts pinging, knocking and all that sort of stuff pretty much just back it off so its safe to drive around
Are you using a 0.7 compressor cover? If so, get it up to 22psi :P
and i repeat.... we ran into ignition problems which was y i wasnt able to run any more then 16psi
compressor housing is a A/R 70 with anti surge
Edited by STR8E180
https://www.sau.com.au/forums/topic/220278-dyno-results/#findComment-3884395
nice for a daily driver str8e180 :) will be good to see the result with the ignition sorted.
yeah its a perfect daily cant believe how responsive it is
feels alot more responsive then when it was all standard
ill post up the new dyno results once i have upgraded the ignition system, im just abit broke to do it right now
Edited by STR8E180
https://www.sau.com.au/forums/topic/220278-dyno-results/#findComment-3884418
It'll be interesting to see how it goes with more ignition pumping in there. Hopefully improve that midrange.
The .78 is an interesting housing, it should have the best of both worlds (good respective points of the .68 and 82)
Twins would be on nearly 1000rpm sooner (5k rpm/200rwkw is fairly laggy in my book for a GT35/700hp setup) so it gives room for lots more tuning and playing once you get stuck into it
https://www.sau.com.au/forums/topic/220278-dyno-results/#findComment-3884816
yeah its not a standard housing option for the GT35
its a modified garrett exhaust housing taken from some other turbo machined to suit the GT35
the compressor housing has the anti surge slot machined in as well
all turbo work was done my ATPturbo.com
im pretty happy with the result ive got so far just need to fix the ignition problem
Edited by STR8E180
https://www.sau.com.au/forums/topic/220278-dyno-results/#findComment-3884950
It does look like a good start, though I largely share Nismoid's opinion at this stage. (Not so much regarding any comparison with twins though)
I've been waiting for this build to come together so that we could see real evidence of what a proper split pulse system is capable of. Let's see the ignition fixed, and tuning continue :(
Edited by Dale FZ1
https://www.sau.com.au/forums/topic/220278-dyno-results/#findComment-3885054
Sorry, what do you base that on? It's making 16psi at 4k, what twins make 16psi at 3k and are able to support 700ps? (~550+rwhp). Forget what "power" it's making, thats obviously just a product of the tune.
I'm running HKS 2835 48T's which are rated at 760ps (not much more than a .86 GT35) and they don't see full boost (1.7bar) until 5800 in 4th...
Edited by Brockaz
https://www.sau.com.au/forums/topic/220278-dyno-results/#findComment-3886362
The ignition you can run with WI skews the comparison with Kemp's setup imo :)
~300rwkw@1bar is on par with other 35R setups so far. Anticipating the results when ignition is sorted :D 35R's are the way of the future, ppl just dont know it yet :)
https://www.sau.com.au/forums/topic/220278-dyno-results/#findComment-3886532
dont worry brockas he loves comparing apples to ballbearings to support his twins fantasy :D
https://www.sau.com.au/forums/topic/220278-dyno-results/#findComment-3886583
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
