Hey all,
About a month ago i purchased a 32 gtr but it wasn't until recently i noticed that the front left air duct is blocked off with what feels like a piece of rubber. Is this normal on a stock gtr? The front bar has been resprayed and i'm starting to think that its been left on afterwards. Would this having any effect on the intake?
Thanks
https://www.sau.com.au/forums/topic/222360-does-this-look-right/
Have you checked to see what's behind the cover? If there's an oil cooler there it's got the cover there to keep oil temps up during winter, and taken off during summer/track days.
During a respray the bar will be removed, so it wouldn't need covers to be placed on it.
I'd remove it, but as long as it's not blocking airflow to radiator/intercooler it won't be a drama.
Got my stock gtr r32 and It also came with the rubber flap. It's factory fitment
If you have a look under ther wheel well plastic lyner you will also have a box resinator.
I removed all those and some more plastic intake crap
Got to be at least an extra 100kw worth of more power now :D
Hey all,
Thanks
LOL that looks like masking tape thats been left on after the respray...
it's factory. you can remove it if you want but just removing it wont do anythnig except cost you some aero.
however your car has definitely been resprayed (and not too well by the look of it). the blanking plate from the factory was just black on call cars. damn, I just noticed they painted the factory lip too. what a shame ;)
well lots of GTRs have had them removed over the years. people remove them, and remove the resonator box behind it too. and the duct can be useful if you put an oil cooler in there or use some pipe to duct cool air up to your airbox/pods. but unless you put either of those in there you may as well just leave the blanking plate in.
Behind the wiper bottle on 32R's is a bung that when removed allows air to travel from the left duct...ARC make a vented plate that fits on the wheel well to allow the rest of the air to pass through or vent hot air from an oil cooler. Or you could get a local shop that does vents for hot rodders to do one for you and save some cash
ARC Wind Master
Thanks for your reply guys. If it came like that from the factory i may aswell leave it. Will the ARC vent significantly reduce heat around the intercooler? As Mr Keets & Beer Baron said, I can't see it being very beneficial unless you have an oil cooler.
ARC Wind Master
go down to bunnings and get a house vent cover and cut it in half... $5 / 2 = $2.50
gold.
Femmo - Duno man, doesn't look like tape / butchers paper to me. Looks like black ABS plastic with a grey sheen due to the camera flash... looks kinda factory lookin? lol.
A resonator is a "tuned space" (empty box) attached to the inlet track, used by manufacture to try and tune intake resonance drone out of the system. Theres nothing factory that takes in air from that brake duct.. hence filling it up.
Edited by GeeTR
GeeTR is correct. Some cars have a resinator on the intake before the air filter to quieten the induction noise. It's the first thing I took off my wrx and r32 gtr. I see em as a restriction to the air intake. I would suggest if you got one on your car remove it.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
