Mark did u really leave ur credit card there or are u just teasing me :)
No I fckign did! Was in such a rush to see my cousin off at the airport I forgot to pick it up...
Are they open tomorrow???
  • Replies 461
Posted Images
Great Night out...
now here comes all the excuss's!!!
kart blew another clutch and cost us 3 laps in the pits and an extra 5 seconds on the inlap... gotta love the luck of green wang pump.
the snaggas at the end were much tastier than the humble pie dessert, well done to Mikey & Bard for their SAUWA 1st placing and also to Tomski for the unbelievable hot lap.
The guy there mentioned to me a 24 hour enduro coming up in November... maybe worth while putting together a SAUWA team?
Im in for the next 1 hour enduro though... great night and the trophy is mine next time so long as the clutch holds out!!! :)
Great Night out...
Im in for the next 1 hour enduro though... great night and the trophy is mine next time so long as the clutch holds out!!! :banana:
Hmm.. this is a bit off topic.. but now i know why was there a pimped up territory there :D sweet car mate :)
Scotty talks cheap!
You were doomed from the start... Makka was late
you lost the foot race at the start, and got owned by Team RamRod
yeah... not all of us have legs long enough to propel us down that main straight in two steps. Go-go mikey legs.
tonight was awesome, big thanks to mike and bard for organising it too abd for our kart with one of our engines that kept on cutting out
i would like everyone to know however that i won the footrace at the start :)
Who would like to do another one of these events around late November?
It was great fun. There are quite a few good drivers out there and some that need a slap for their driving etiquette...not that i would name names or anything Bart! :)
Tom, i still claim its a electronic error that gave you the 58 second lap...however, it was a fantastic lap and i acknowledge that your fast laps times were quite consistent.
To summarise the event, i would say TEAM RAMROD FTMFW!!!!!
*takes a bow*
It was great fun. There are quite a few good drivers out there and some that need a slap for their driving etiquette...not that i would name names or anything Bart! :banana:
*takes a bow*
Im in for another for sure :)
Brad im surprised you even felt that bump :D
*takes a bow*
Im definitely in :D
P.S. Someone went up my ass quite hard at the 1st or 2nd corner.. :) sorry whoever that was.. Don't know who's at wrong.. but.. i just waved my hand to say sorry
awsome night, those carts can go sideways alright :D my misses told me that when i came onto the main straight my cart was making skidskid noises, suprised we came 4th or 5th with nearly a flat 1min time, my co driver had never carted before and i dont think i did a dfull lap without tryna slide it :)
Yeah, you where a place ahead of us...
lol, my cousin kept asking me who was that bloke constantly loosing traction onto the start-finish straight...
Non other than Sam ey??? :banana:
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
