Hi,
A mate of mine is having troubles with his R33.
As soon as it hits about 5500rpm it just stops accelerating and starts back firing. or if it doesnt back fire it just stops reving and stays @ 5500rpm...
We are certain that is not coil packs as we have had many coil pack issues before and this isnt the same.
The car had a Power FC, Z32 ADM and a 044.
The now has a Stock ECU, AFM and fuel pump.
Also today is the first time the car has been driven since August..
Any help appreciated!!
https://www.sau.com.au/forums/topic/223844-r33-problems/
nah if its running fine up to 5500 rpm it wont be plugs or fuel, if it was either of those it would be coughing and spluttering right through the rev range,
but will need a few questions answered before being able to tell what it is causing it, is the afm still ok, have you swapped it with that of another car?
is the car running standard boost. if it had a z32 on it was the setup outflowing the standard afm? if so take the boost back down to standard.
R33, variable timed yes, is the solenoid still operational that lets oil flow to the lifters?????
the ecu alters fuel values when the system is activated by the rpm, flooding perhaps and detonating violently?
if so unplug the O2 sensors and leave them off for the time being as the ecu would be compensating for the richness,
also unplug the ecu temp sensor, this will force the ecu to go into normal operation as if the engine had warmed up.
is the base timing correct, assuming it was running a aftermarket ecu, afm, etc was this altered at all?
https://www.sau.com.au/forums/topic/223844-r33-problems/#findComment-3943506
It seems to have lost alot of power throughout the hole power range. But hasnt lost any boost.
Also little puffs of black smoke seem to come out the rear so it couldnt be the fuel pump if its running rich??
Could it be the afm??
https://www.sau.com.au/forums/topic/223844-r33-problems/#findComment-3945482
Almost a thread a week on this these days… *sigh*
Your running increased boost on the stock ECU. Its therefore having a fit/hernia/spaz etc etc.
Back off the boost, car will return to normal as its closer to factory. RB25 ECU's don’t like much over standard boost pressue in many instances
https://www.sau.com.au/forums/topic/223844-r33-problems/#findComment-3946101
It is a constant problem at the 5500rpm mark? My car is having similar issues, but its temperamental. Some days it drives great, other days its terrible, and of course whenever I take it to the mechanic it decides to have a good day, or half-week as it were last time.
In any case, next time it plays up I'm driving it straight to him. I'll post here on what he finds.
https://www.sau.com.au/forums/topic/223844-r33-problems/#findComment-3947828
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
