just throwing up some pics of my latest project.... big thanks to Gavin from wades automotive for an awesome paint job....highly recommended after this.
Eli's 34 has always made me moist! As always champ great choice on paint and combo of GTR parts.
Think jade looks lame on coupes but the gtr sedan it looks very nice , classy with a bit of sinister lurking
Looks the goods eli
new engine came in from brissy, cleaned n painted n sat my turbs set up on it for a pic :P
Is that the same one you were getting ready when I popped out for some parts?
It looks great :)
Something about my backyard is always good for pics
Hasnt been washed in ages, has copped a huge stack of pollen off the olive tree (car normally sits under the back carport if not in the shed, and its downwind of the tree :/)
*edit* pic helps dickhead LOL
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
