pretty similar with the conversion....I think it was u that put me onto it in the first place! and after doing some research and giving it a go I reckon its def. better (if u can afford it)
Yah... expensive but its good stuffs. >_<
Edited by Trex101
Trex101, you sound like you really know your oils. I've got a bottle of full synthetic Fuchs Titan Super GTO 10w-30, do you reckon it should be alright to put in my stock 33? I treat it like there's a baby in back seat and only rev her out about once or twice per tank of fuel. With that oil what should be my oil change intervals? It's usually 5000km but could i stretch that out a bit more?
Not familiar with Fuchs GTO... Is it semi or fully syn? For turbo application, best to use group IV fully syn oil. I read from BITOG that you guys can get Mobil Delvac 1 5w40 for AU$30+ bucks per 5L. That's hell of a good deal over there. Go get that oil, it's a top notch oil for that type of pricing...
Yeah its fully synthetic. The guy that sells it runs it in his stock car(you know the cars that are constantly going sideways around a circular mud track). He sells it for $36.
The thing you need to remember is the rating of the oil. When the GT-R was released, ie late eighties the oil grade was something like SF or SG or thereabouts. Now it is SM or similar. Each change from SF to SG and so on is a quantifiable gain in the protective qualities of the oil. So just about any current oil will be markedly better than what was put in the engine when it was released.
i totally i agree..... i think its more important to change your oil and filter regularly than worrying to much on the quality of the oil....
a car running a cheaper oil changed often vs a car running a motul oil thats never changed is better imo......
either way
anyway
im a motul user too....
on the mobil site it says the 5w40 delvac oil is for diesels, is it ok for petrol engines too? please explain..?
5W-40 is OK...nothing special tho...but as trex101 said its good value for money...
Edited by khunjeng
It's a dual rated oil with API SL (petrol)/CI-4 rating (diesel). This oil is make up of mostly group IV/V plus a very strong additives package due to the fact that diesel engine are alot more stressful & high load environment for the oil than petrol engine.
If it's cheap, use it. This oil can last much longer than 10k km OCI anytime.
I use Delvac 1 and for the money, its second to none, and is one of the worlds best oils, regardless of price. In fact, if anything it is better than their own Mobil 1 Super Syn range.
Its a pity its so hard to find though.
ok so what oil is best for a 16 year old rb20det? I have being using semi syn 15 w 50 or Pennzoil for a year now, but after reading all this i am beginning to think this oil aint really good for a engine my age? i hear conflicting reports that old engines shouldnt be using "thin" oil like 5w 30w etc, can someone clarify please?
thankyou
oh i ALWAYS change oil and filter at 5000-6000km, i am interested in using a oil that genuinely cleans the engine, as i think 15years of japanese air must not have done it much good. (its done 86000..but we all know about kmz on skylines lol)
If budget is no issue, use ester base Redline 10w40 or 5w40. The ester will slowly but surely clean all the junk out of the engine.
I've been using nothing but Motul 8100 5/40.
Was thinking of going 5/50 for track use but probably won't - will keep 5/40 and get an oil cooler. Would that be ok?
Also, anyone used ELF excellium 5/40? I've been thinking of switching, I think ELF are marketing excellium to take the 8100 market and for $10 if it's the same or better I'll switch.
I wish justjap wasn't so far away genuine nissan filter + 8100 5L for $65 ! Anyone know a place on the Northern Beaches/Shore that will do that!?
  • 3 weeks later...
Hey, i just called a place in sydney which sells this off the shelf (generally) and they want
$236inc gst for 20L
or
$177inc gst for 3x5L bottles
so its more like $60 for 5 litres not $30 unfortunately!
FYI the place is called fuel direct, in homebush 1300 781 982
fot that price you can get motul 8100(5w-40 as well), which do you think is better?
This might be of interest to those of you who like objective information; i've made a small table with some oil specs on it.
If anyone can find Motul specs PM me and i'll update the table. If anyone can tell me how to make an html table appear in a post, PM me. Pasting the HTML didnt work.
http://www.jaftan.com.au/skyline/engine/oilspecs.html
Rgs,
Kot
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
