pretty similar with the conversion....I think it was u that put me onto it in the first place! and after doing some research and giving it a go I reckon its def. better (if u can afford it)
Yah... expensive but its good stuffs. >_<
Edited by Trex101
Trex101, you sound like you really know your oils. I've got a bottle of full synthetic Fuchs Titan Super GTO 10w-30, do you reckon it should be alright to put in my stock 33? I treat it like there's a baby in back seat and only rev her out about once or twice per tank of fuel. With that oil what should be my oil change intervals? It's usually 5000km but could i stretch that out a bit more?
Not familiar with Fuchs GTO... Is it semi or fully syn? For turbo application, best to use group IV fully syn oil. I read from BITOG that you guys can get Mobil Delvac 1 5w40 for AU$30+ bucks per 5L. That's hell of a good deal over there. Go get that oil, it's a top notch oil for that type of pricing...
Yeah its fully synthetic. The guy that sells it runs it in his stock car(you know the cars that are constantly going sideways around a circular mud track). He sells it for $36.
The thing you need to remember is the rating of the oil. When the GT-R was released, ie late eighties the oil grade was something like SF or SG or thereabouts. Now it is SM or similar. Each change from SF to SG and so on is a quantifiable gain in the protective qualities of the oil. So just about any current oil will be markedly better than what was put in the engine when it was released.
i totally i agree..... i think its more important to change your oil and filter regularly than worrying to much on the quality of the oil....
a car running a cheaper oil changed often vs a car running a motul oil thats never changed is better imo......
either way
anyway
im a motul user too....
on the mobil site it says the 5w40 delvac oil is for diesels, is it ok for petrol engines too? please explain..?
5W-40 is OK...nothing special tho...but as trex101 said its good value for money...
Edited by khunjeng
It's a dual rated oil with API SL (petrol)/CI-4 rating (diesel). This oil is make up of mostly group IV/V plus a very strong additives package due to the fact that diesel engine are alot more stressful & high load environment for the oil than petrol engine.
If it's cheap, use it. This oil can last much longer than 10k km OCI anytime.
I use Delvac 1 and for the money, its second to none, and is one of the worlds best oils, regardless of price. In fact, if anything it is better than their own Mobil 1 Super Syn range.
Its a pity its so hard to find though.
ok so what oil is best for a 16 year old rb20det? I have being using semi syn 15 w 50 or Pennzoil for a year now, but after reading all this i am beginning to think this oil aint really good for a engine my age? i hear conflicting reports that old engines shouldnt be using "thin" oil like 5w 30w etc, can someone clarify please?
thankyou
oh i ALWAYS change oil and filter at 5000-6000km, i am interested in using a oil that genuinely cleans the engine, as i think 15years of japanese air must not have done it much good. (its done 86000..but we all know about kmz on skylines lol)
If budget is no issue, use ester base Redline 10w40 or 5w40. The ester will slowly but surely clean all the junk out of the engine.
I've been using nothing but Motul 8100 5/40.
Was thinking of going 5/50 for track use but probably won't - will keep 5/40 and get an oil cooler. Would that be ok?
Also, anyone used ELF excellium 5/40? I've been thinking of switching, I think ELF are marketing excellium to take the 8100 market and for $10 if it's the same or better I'll switch.
I wish justjap wasn't so far away genuine nissan filter + 8100 5L for $65 ! Anyone know a place on the Northern Beaches/Shore that will do that!?
  • 3 weeks later...
Hey, i just called a place in sydney which sells this off the shelf (generally) and they want
$236inc gst for 20L
or
$177inc gst for 3x5L bottles
so its more like $60 for 5 litres not $30 unfortunately!
FYI the place is called fuel direct, in homebush 1300 781 982
fot that price you can get motul 8100(5w-40 as well), which do you think is better?
This might be of interest to those of you who like objective information; i've made a small table with some oil specs on it.
If anyone can find Motul specs PM me and i'll update the table. If anyone can tell me how to make an html table appear in a post, PM me. Pasting the HTML didnt work.
http://www.jaftan.com.au/skyline/engine/oilspecs.html
Rgs,
Kot
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
