Good choice on the Castrol, their 0W40 product is also of high quality. PureOnes are also a very good choice, streets ahead of Ryco and I'd say Nissan OEM too.
With the 0w 40 edge the car seems to run 5 degrees cooler than the 10w 60 edge.
last three changes have been royal purple, turbolite turbolite, i just ordered 3 5l bottles of delvac 1 5w-40 should have them on wednesday ill see how they go. i know its way better than turbolite i just hope its a good choice for the money ~60/5L it seems to be a perfect viscosity for skylines and our climate at least, and everyone seems to regard it very highly..
I was under the impression the castrol 5w30 and 10w60 is actually a GRP III oil?
And here's an interesting little bit of history..
In the late 1990s, Castrol started selling an oil made from Group III base oil and called it SynTec Full Synthetic. Mobil sued Castrol, asserting that this oil was not synthetic, but simply a highly refined petroleum oil, and therefore it was false advertising to call it synthetic. In 1999, Mobil lost their lawsuit. It was decided that the word "synthetic" was a marketing term and referred to properties, not to production methods or ingredients. Castrol continues to make SynTec out of Group III base oils, that is highly purified mineral oil with most all of the cockroach bits removed.
http://motorcycleinfo.calsci.com/Oils1.html
Yah, only Castrol 0w30 aka german castrol are PAO/ester blend. Do you guys have that in Australia? I'll be importing some to Singapore for own use & testing.
German Castrol 0w30
Edited by Trex101
Castrol have always been Group III, besides their 0W40 which has been PAO, so I would say they price their 'synthetics' accordingly against Mobil 1. Trex101, we don't get GC down here. Aussies aren't keen on 30 weights.
To explain what I said before, Motul Turbolight is a semisynthetic, not even a Group III which makes it a ripoff at $50 a bottle. You can get Group IIIs such as EDGE 5W30 or Helix Ultra for the same price.
hi guys :O
I've read the whole thread. I'ma girl and just can't get my head around all the tech talk about oils and what the numbers mean. :(
on the stagea forum they recommend Castrol Formula R Synthetic 10W60 or 0W40... From this thread I'm getting that the castrol 10W60 is not a good choice? I have a 1997 Stagea... help !
Also how many litres would the car take?
hi guys :O
We need more infor like mileage, type of driving (heavy or light footer), short or long trip (km) and if there's any oil consumption? Only with all the infor provided then we could give you a better advice.
Edited by Trex101
oops sorry
the car has done just over 70k
I'm a bit of a lead foot
Driven Daily..small trips... with roughly 100k trip a fortnight.
Just drove it over 2000k across the nullabor with no oil consumption.
Oil is black :O
Doing oil change this weekend :( With a bit of help :)
oops sorry
Oil is black :(
Doing oil change this weekend :D With a bit of help ;)
A 40wt oil like 5w40 or 10w40 oil will do under this type of condition. Since it's a turbo, at least a PAO base oil would be good. Oh what's your budget for oil?
hi all just joined sau and got my new toy last weekend and i am in the hunt for some info but i will be using penrite hpr 15 on my r33 gts-t for its wide range of protection i used it on my old now 19yo r31 and no oil use and over 350,000ks
but and used it on my 2 cars before that (turbo coridas) they wernt the best but they lived till io sold them
well what is needed is a thin oil which flows easy hence as many have said the 0-20 and less range but not breakdown on high heat like a turbo and aussie conditions are as hot as they come as we all know so 40-60 range is needed for best protection .......
someone correct me if i'm wrong so i use hpr 15-60 becasue it does both well and only about 30 bucks for 5 ltrs
i seen this towards the front of the thread
Engine: Shell Helix Ultra (Synthetic) 15w-50 or 5w-40
Man Tranz: Shell Spirax CX 80w-90
Diff: Shell Spirax AX 80w-90
Power Steering: Shell ATF Dexron III
this written eariler in this thread and i would be thinking go a straight 80 oil for the GB for that should lead to a smoother shift :D
so this weekend its getting a total fuild change for some of this stuff could have been in it since factory so its goin to be engine, GB, diff , clutch, brakes , power steer this will cost me around 100$ but it will be ok for a will know its got good clean oil everywhere
and stageagirl oil $35 and $10 for a filter
Up to $100 plus oil filter
How many litres will I need?
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
