5.5L of Nulon 10w40 fully synth shit went in. ~4L comes out. After 4000km. What shit. Last oil I used was 8100 5w40, and the entire 5L came back out when I dropped it. This oil breaks down and burns very easily, won't be using it again after I get through what I put back in (like I said previously, got 10L cheap so couldn't turn it down). It also stank a bit more than it should.
Will be keen to try out the 8100 10w40 stuff next.
wow that's an awful lot to burn and you definitely don't normally burn oil?
Definitely not. Never noticed it out the exhaust (on or off boost), have fark all blowby (absolutely nothing came out of the catch can) and as I said with the previous oil drop, the whole 5L came out whereas this one was a lot less :(
Might honestly just be the oil, which wouldn't bother me too much. Would rather the oil be ghey than have bigger problems.
Been using Nulon 10W-40 since I bought the car 2 years ago with no probs....serviced roughly every 5000km +/- few hundred Ks.
However, I recently switched to Motul X-Max 10W-40 cos its only like $7 extra from Autobarn (for 5 litres) compared to the Nulon (6 litres worth).
I haven't noticed any difference apart from peace of mind knowing that the stuff in the car is "a quality brand" and is guaranteed to be 100% synthetic POA/ester based :closedeyes:
holy degrease batman, put some of the $15 gulf western into my new corolla daily
i haven't even put 2 tanks through it and its gone black :)
i'm pretty impressed with it, i've been wanting a car of my own to try it on for ages
haha, I'm hoping that might have been why my shithouse Nulon went black after 4000km - did a better cleaning job than 8100.
Sadly, I think I'm wrong.
So this $15 GW business, might do my noisy lifter some favours if I could be arsed changing the oil twice in a fortnight
i think all the gw oils are good at degreasing is what i was trying to say
i'd go the synx 3000 for a skyline (20w50 is too thick for me)
Hey Guys,
So what do you think about Mobil 1 Gold??? I tried castrol edge, and dropped it after a few hundred k's cause the car felt sluggish, as soon as the Mobil went in the car started sweetly and the difference seems obvious, event the turbo sounded more crisp...
Stays the same clear gold right upto the next oil change and never goes down on the stick...Does this mean its a good oil or are my oil rings just sealing off really well??
detergents aren't working if the oil doesn't come out black right?
yes and no. Black oil doesn't always mean detergents are working....can also mean burnt oil. I'd also say that just because the oil comes out a bit lighter colour, doesn't necessarily mean that detergents aren't working. Might just mean it was nice n clean inside and you didn't get the oil hot enough to gunk up any further.
That's correct, there are a lot of ways to read the colour of an oil. Logic needs to be applied.
A guy I used to know put some oil in his car before getting dyno tuned...his tuner checked the oil afterwards, found it was black and incorrectly assumed it was a shitty oil. Couple of problems here:
- Dyno tuning and other intensive engine work (racetracks etc.) can burn an oil no matter how good it is. This is important to keep track of, as extreme driving behaviour can shorten appropriate service intervals in street cars.
- Previous oil may not have had as much detergent in it, leaving plenty of build up for the new oil to drain out.
As the other's said, if after 5-10k the oil comes out golden it has lasted well but not cleaned the engine at all, if it comes out black it has either broken down, cleaned well, or both (I'd guess usually both). You can gt some idea by smell bit it's a bit subjective, though you do know if it smells burnt to all hell it's broken down badly.
You still using sougi birds? What will be your choice when your stockpile runs out? I'd be looking towards xcess or xmax. Is that synx 3000 stuff detergent heavy? Maybe that's the cheaper way to go these days.
Yeah I'm still on Sougi...I have a personal stash leftover, but I'll probably make the switch to Syn-X after that...only because I can use it in my car for free haha. I have thousands of litres of it. But it is a decent oil nonetheless. If I wasn't a distributor I'd probably consider Motul too.
for best all round performance on the street 8100 xcess is the shit imo.. I use 5-40,
Mobil one or gold is decent enough too so is penrite syn.
I didnt like castrol
Burnt oil will be black and thin/runny, if your oil drains out fast it is probably burnt or just not good oil..Good oil should be darker than when you put it in of course, but it shouldn't be black unless your engine is tired and it should drain slow towards the end.
i want to know has anyone tried Fuchs oils and what are they like, can get 20l drums of full synthetic for about 150$ just want to use it in my work ute mainly
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
