5.5L of Nulon 10w40 fully synth shit went in. ~4L comes out. After 4000km. What shit. Last oil I used was 8100 5w40, and the entire 5L came back out when I dropped it. This oil breaks down and burns very easily, won't be using it again after I get through what I put back in (like I said previously, got 10L cheap so couldn't turn it down). It also stank a bit more than it should.
Will be keen to try out the 8100 10w40 stuff next.
wow that's an awful lot to burn and you definitely don't normally burn oil?
Definitely not. Never noticed it out the exhaust (on or off boost), have fark all blowby (absolutely nothing came out of the catch can) and as I said with the previous oil drop, the whole 5L came out whereas this one was a lot less :(
Might honestly just be the oil, which wouldn't bother me too much. Would rather the oil be ghey than have bigger problems.
Been using Nulon 10W-40 since I bought the car 2 years ago with no probs....serviced roughly every 5000km +/- few hundred Ks.
However, I recently switched to Motul X-Max 10W-40 cos its only like $7 extra from Autobarn (for 5 litres) compared to the Nulon (6 litres worth).
I haven't noticed any difference apart from peace of mind knowing that the stuff in the car is "a quality brand" and is guaranteed to be 100% synthetic POA/ester based :closedeyes:
holy degrease batman, put some of the $15 gulf western into my new corolla daily
i haven't even put 2 tanks through it and its gone black :)
i'm pretty impressed with it, i've been wanting a car of my own to try it on for ages
haha, I'm hoping that might have been why my shithouse Nulon went black after 4000km - did a better cleaning job than 8100.
Sadly, I think I'm wrong.
So this $15 GW business, might do my noisy lifter some favours if I could be arsed changing the oil twice in a fortnight
i think all the gw oils are good at degreasing is what i was trying to say
i'd go the synx 3000 for a skyline (20w50 is too thick for me)
Hey Guys,
So what do you think about Mobil 1 Gold??? I tried castrol edge, and dropped it after a few hundred k's cause the car felt sluggish, as soon as the Mobil went in the car started sweetly and the difference seems obvious, event the turbo sounded more crisp...
Stays the same clear gold right upto the next oil change and never goes down on the stick...Does this mean its a good oil or are my oil rings just sealing off really well??
detergents aren't working if the oil doesn't come out black right?
yes and no. Black oil doesn't always mean detergents are working....can also mean burnt oil. I'd also say that just because the oil comes out a bit lighter colour, doesn't necessarily mean that detergents aren't working. Might just mean it was nice n clean inside and you didn't get the oil hot enough to gunk up any further.
That's correct, there are a lot of ways to read the colour of an oil. Logic needs to be applied.
A guy I used to know put some oil in his car before getting dyno tuned...his tuner checked the oil afterwards, found it was black and incorrectly assumed it was a shitty oil. Couple of problems here:
- Dyno tuning and other intensive engine work (racetracks etc.) can burn an oil no matter how good it is. This is important to keep track of, as extreme driving behaviour can shorten appropriate service intervals in street cars.
- Previous oil may not have had as much detergent in it, leaving plenty of build up for the new oil to drain out.
As the other's said, if after 5-10k the oil comes out golden it has lasted well but not cleaned the engine at all, if it comes out black it has either broken down, cleaned well, or both (I'd guess usually both). You can gt some idea by smell bit it's a bit subjective, though you do know if it smells burnt to all hell it's broken down badly.
You still using sougi birds? What will be your choice when your stockpile runs out? I'd be looking towards xcess or xmax. Is that synx 3000 stuff detergent heavy? Maybe that's the cheaper way to go these days.
Yeah I'm still on Sougi...I have a personal stash leftover, but I'll probably make the switch to Syn-X after that...only because I can use it in my car for free haha. I have thousands of litres of it. But it is a decent oil nonetheless. If I wasn't a distributor I'd probably consider Motul too.
for best all round performance on the street 8100 xcess is the shit imo.. I use 5-40,
Mobil one or gold is decent enough too so is penrite syn.
I didnt like castrol
Burnt oil will be black and thin/runny, if your oil drains out fast it is probably burnt or just not good oil..Good oil should be darker than when you put it in of course, but it shouldn't be black unless your engine is tired and it should drain slow towards the end.
i want to know has anyone tried Fuchs oils and what are they like, can get 20l drums of full synthetic for about 150$ just want to use it in my work ute mainly
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
