for $10 more I would be going for the full zinc Racing 10
http://www.penriteoil.com.au/pis_pdfs/010%20TENTHS%20RACING%20OIL%2010%20NOV%202012.pdf
I bought the 10 Tenths Racing 10 in a 20l drum for about $120.
Trouble is...
I can't remember if it was on this F/S forum or the OzFoz F/S forum - sorry
For normal service intervals on a road going car, the enviro 5w-40 would be a far smarter choice than the 10 tenths racing. Reason being that 10 tenths is ester based and only designed for short service intervals (one change per race day) and has a dreadfully short effective lifespan. I'm pretty sure it also doesn't meet or exceed any of the last 3 or 4 API ratings...
That sucks :(
Is Mobil 1 0w-40 okay to use in a non turbo r34?
Bit thin, try 5w-50
That sucks :(
Bit thin, try 5w-50
There is some truth in what he said there in that racing ten doesn't have the latest ACEA ratings like A4 A5/B5 like the Enviro but the rest is complete BS.
Racing 10 does have high zinc (ZDDP) which is good for RB engines especially Neo's and RB26's with solid lifters, oils with high zinc and phosphorous levels tend to clog catalytic converters faster and hence they don't meet the latest standards for petrol/ diesel economy engines designed to run in California with their strict laws.
It's service life is fine for daily driving, hence it's A3/ B3 rating...
For use in high performance petrol and diesel cars and light commercials where extended drain intervals are specified by the vehicle manufacturer and / or for year-round use of low viscosity oils and / or for use in severe operating conditions as defined by the vehicle manufacturer.
...probably one of the better oils to use in an RB!
Edited by Missileman
On my GT-R I went from HPR10 to SIN5 to Racing 10 (couldn't find Premium 5). The 10 tenths made the most noticeable difference, the engine runs smoother and quieter compared to the other two oils. Hopefully they last 10,000km lol.
TJZ - 10W-40 is not too thick, Nissan 200SX oil (from Nissan) is 7.5W-30, so 10W-40 or thereabouts is fine for daily driving. If you're thrashing your car a lot then look at getting thicker oil (5W-50 or 10W-60 etc.).
My apologies, I was about to start ranting and raving and calling you names when I thought I'd better check the Penrite website. It appears as though the formulation has been updated since I left the industry and now complies with the latest API (SN) rating AND they've done something about it's service life.
This will actually make my next oil change a difficult decision as I always like the ten tenths range based on its other benefits (friction/cleaning) :)
Thanks for the heads up (even if it was a little blunt)...
That's OK. It takes a man to update; even if it conflicts with previous info supplied.
One of the Z-Tunes in Oz was run on Elf Excellium SC 5W-40 which I then ran in my previous VS2.
I didn't have it long enough to see incremental changes at each oil change.
no apology necessary, some times i'm blunt, some times i'm sarcastic, a lot of the the time i'm just plain rude, i put it down to old age.
oh and I'm not trying to push penrite, in fact i've never used it, though i may give it a try next change.
I'm surprised they don't use something like Mainlube in such a rare motor!
Yeah, well it went off to Greece.
Probably not worth much under it's economy; but perhaps it can be resold in a richer country.
Back to thread, that Z-Tune was being serviced here in Sydney by an RB specialist.
The penrite 10 tenths is good stuff. I've used the Penrite racing 5 oil (now 10 tenths) since I got my old ford laser years ago with about 250,000k's on the clock. It's now done near 360.000k's and it's still going strong despite being given some hefty punishment over the years. I used to do changes every 10,000 but it's down to about 5-6000 now because it slowly gets noticeably more sluggish and rough after that in it's old age.
I've been using Penrite since I started driving. HPR15 in my R31 for 5 years no issues.
With my GT-R, went from Mobil 1 5W-50 to SIN5, engine ran noticeably smoother and the pressure was more consistent at 5,000 km compared to fresh oil. The 10 tenths is even smoother again (by not much).
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
