Generally, unless you're radically changing oil viscosity or the old oil is very old/dirty, you're usually fine to just get the oil up to temp, drop it (don't burn yourself) and throw a new filter on with some fresh oil of your choosing.
Thanks for that, thinking of going penrite HPR 5w-40 full synth. Or the everyday+ 5w-40 semi-synth. Edited by Zrobe
Could all be placebo but...
Going from Motul 8100 xcess 5w/40 to Gulf Western Synx 5w/40.
The motor feels a little more..."lethargic" during initial start, like it won't rev up as freely/easily/quickly.
Could just be the weather....
I checked out the spec sheets of both Motul 8100 xcess and Gulf Westerns Synx6000, both were very similar on paper. even the Penrite HPR 5 is similar....
Could be just the cold weather...or there is something different between them that isn't counted on paper.
  • 4 weeks later...
hmmm.
missus mazda 3.
was using penrite everyday syn 5w40.
engine has approx 130k.
went to motul 8100xcess.
feels alot quicker and more responsive.
might be the oil.
I use the cheap $22 GW Synx-3000 semi-syn oil in my car & doesn't notice anything compared to what ever stuff was put in there by the work shop before.
I changed it every 5k km or 6 month & the car (used) to be a daily driver (no tracks) so I don't see the point of spending >$40 for oil.
I've come to the same conclusion too, when you work out what you save over a 100k km on the $70 oil it adds up to nearly the cost of a low K wrecker motor.
Have read the last few pages of the thread but to be honest it's a bit all over the place. Just wanting to know what brand/weight of oil to use in my car.
RB25DET Neo with 130xxx k's on it. Will be my daily but I will hopefully be doing a few track days and 6-7 drift days per year and I will be driving it fairly hard. Where I currently am the temperature he's down to about 0 overnight and about 20 during the day.
Not really sure what brands are good and what weights for climate/engine age so any info would be handy, thanks!
What brands would you suggest? Or doesn't really matter as long as its fully synthetic?
This engine won't have been started in about a year either, am I best off buying some helper stuff to put in at first start up then changing the oil once I know it's running fine?
Been digging through this thread quite extensively but still having trouble making up my mind, hence my current post.
Just wanted some opinions on what oil i should be using for my next service. This will actually be my first service since owning the car so i don't wanna skip out on anything. I'm willing to spend big $$$ to make sure my pride and joy is running at its best. Through my reading, i've come across some good rep for SYN-X 3000, Mobil 1, Motul and Royal Purple.
CAR DETAILS
'98 Skyline R34 25GT (Coupe)
Automatic
Approx. 93,000km
Never tracked
It's been recommended to me, based on the number of kms the car has done, that i should be going for something along the lines of... Fully synthetic 10W-40.
Any info would be appreciated,
Cheers
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
