I was originally gonna try doing exactly that with one of those nulon "lifter free" engine flushes but then I read some guy on SAU or maybe elsewhere did the same thing to try and free up the lifters and apparently it did such a terrific job of cleaning out all the crud his rattling amplified ... lawl. Imagine that shit. And there's no going back from that ..not like you can poor sludge back in to quiet it down :D So yeah I'm guessing he had to take the lifters out and clean/repair them
Birds how does rocker cover oil flow affect lifters ? Any chance you can elaborate on that ? I do have the tiniest little leak near the half moons / firewall that I've been meaning to fix for a while. Even bought the rocker cover gaskets from nissan like a year ago just never got around to it heh
sougi helped with my lifter noise - r34 spec rb25 (neo)
nulon was good at first then got noisy when cold
i still get a bit of top end noise when cold but it goes away after 20 secs max
which sougi and what viscosity? And what do you mean by top end noise when cold ?
sougi only comes in 10w40
i'll take a video sometime when i do a cold start next
its not tappet noise cos neo heads have solid lifters but its a similar noise. bit of a whirr and a soft rattle
i think i just need to re-do the tolerances (100k km service is coming up)
Hey all,
Just came across this interesting video comparison clip of four well know oil brands seeing which produces most performance. Test conducted a on Mitsubishi Evo 6 via dyno shoot out. Engine Oils were Royal purple, Nulon, Castrol edge & Motul 300V, mobil 1 (all 5w -30) . Link below, im not sure if anyone has posted this before, but i thought it might help those who are researching about oils for your car. =)
Those who are too lazy, Average Kws results were as below: NB (No boost increase during tests to keep fair of course)
1. Nulon: 178.00kws @All four wheels
2. Royal Purple: 173.50kws @All four wheels
3. Castrol Edge: 173.00kws @All four wheels
4. Motul 300V: 172.05kws @All four wheels
5 Mobil 1: 167.05kws @All four wheels
Cheers!
Lee
Edited by shorty_01
Dyno test should be taken with a big grain of salt...when you're talking a few kw difference that can be the difference between two runs with the same oil...but it's not like you buy an oil to increase power anyway. The thinnest oil will generally produce more power because of less inertia on engine internals.
Cause the sound resonates through the camshaft lobe followers, which also need lubrication in their bores...they're like miniature cylinders. Oil also acts as a sound blanket withn the rocker covers. Give Sougi a go, it only comes in 10w40...may not do anything for your lifters but mine are quiet enough and it is a very, very good oil.
Hey all,
Cheers!
Lee
That is very interesting! But unfortunately it can't simulate the effect of the oils on the engine over a few thousand km, such as carbon deposition/removal and other longer term effects of an oil on an engine.
Look at the dyno fan positioning between oils, Nulon is practically on the bumper, whereas the others you could park a motorcycle in there.
Yep too many variables in that for it to be considered as even slightly meaningful. They should have done 5 dynos back to back for each oil to account for any spread, they should have waited for each car to cool down AND they should have used a control car with no oil changes.
I bet there was less than 2kw difference between them all and a dyno is not accurate enough to measure a difference like that.
I've seen that YouTube video and the biggest complaint I've read is about the fan positioning. It seems they did try to do a proper comparison, but there are too many things they did wrong for it to be useful.
Add to that Nulon advertising their oil as 100% synthetic when it's only a semi. If they are not even honest with regards to this, then the performance gains to me are meaningless as I have little confidence in a company that attempts to mislead.
Bottom line is that any dyno competition, no matter how double blind / strict / fair, is useless for comparing oils...the power differences are a couple of kilowatts. Too many variables at stake to put power differences like that down to a different oil. We aren't talking 2000 watt motors here. I've done 3 consecutive runs (2 minutes apart) before, results varied between 162rwkw and 166rwkw...
The competition although fun, is just part of an oil company marketing their oil as a performance product rather than a support product, targeting the sector of auto aftermarket obsessed with extracting every single kw out of their engine.
I've put in royal purple 15W40 and have noticed no change in terms of "lifter noise" on cold startup. Still the same and still goes away after about 1 minute. I'm starting to think it's NOT lifter noise at all .. quite possibly leaky exhaust manifold gasket or snapped mainfold studs. Then as soon as some heat gets there, the small gap closes and the noise stops ...
For the life of me I can't see the exhaust mainfol at all looking through the engine bay .. do I have to remove the undertray and look from below to check the manifold gasket/studs??
Ps. www.performanceclub.com for all your top of the line oils - best prices anywhere and you can get viscosities that normal OZ distributor doesn't even carry (like the RP 15W40)
If its really 15 seconds im sure it would be lifter noise and not leaky gasket noise. I have heard that same lifter noise on a plenty of cars over time.
now I'm 99.99999% sure it's neither lifters NOR exhaust manifold/gasket/bolts .... but rather the timing belt idler bearing.
I got one of those things you stick in your ears connected to a long metal rod (like doctors use when listening to you breathe) and the noise is most loud at the top right of the engine just behind the timing belt cover.
Then i found a couple of vids on youtube from other SAU members who had that exact same noise in the exact same area and when they replaced the idler/tensioner bearings it went away!
Can't frigging wait to get this done now... parts alone cost $600 (nissan timing belt/water pump, idler and tensioner and bearings and studs ... rocker cover gaskets.) How much do you reckon I should pay for labour for all of the above?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
