2000hp from an NA V6....proof please
edit: no chance of that, F1s are (i believe) the highest output per litre car in the world, and they make what?...800hp from 2.4litres of V8 at 20,000rpm, these things spin so fast they use air instead of valvesprings, the metal cant spring fast enough, no chance the yanks build a 2000hp na NSX
Sorry bud. I didnt note the N/A bit. Turbo engines is where I was at.
  • Replies 40
Ohh nice, tho doesnt quiet sound as good as the lfa
it does however look quiet quick
Edited by Angus Smart
As i read that i shook my head and said "that's f**king ridiculous".
Amazing technology.
Its pretty slow and seems boaty, I dont know but didnt see much that impressed me. Sounds like crap but with a aftermarket exhaust will really bring out a note
Yep, sure. Faster than every production GTR up till the R35 - can't imagine what you think of them!
^Exactly what i was thinking. By the time cars like this come out no one will care cause we all will be riding around on pushbikes because fuel stations will have loan approval documentations at the counter just to fill up a tank. It's a bloody joke!!
its said that the nsx will have the same technology like the accord, where by when cruising, it wont use all 10 cylinders - so it may use 5 cyl for just cruising
yeah its called Cylinder Deactivation. its excellent too.
If driven the new accord and you cant even tell that its running on less cylinder other than a light on the dash that says "eco" when its doing it. Its unnoticable
Super-Handling All-Wheel-Drive system
lol
Watch out for the ATTS system that was brought out on a small run of the 5th Gen Prelude...
The Prelude was always a platform for experimentation anyway.
But if they can keep it lightweight, you understand that on any curve, the outer wheels rotate faster than the inner ones.
But like you guys say, it'll take a lot of R&D to catch up to the (lightened) R35 V-Spec (with extra mods) and the newer Porsches.
Interesting Times...
everything has to be super with these people
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
    • 10 minutes on a lathe would be one way to achieve literally anything you want, too. (except for AN type stuff - just talking about M-F with BSP and NPT in any mix/combo).
    • yeah, so "something" should be -4 AN....to a hose....to a -4AN to NPT fitting *edit* sorry, I surely have that backwards. The LS is from land of the free so it must be NPT at the block, and the Nissan sender is BSPT. But still, conceptually the same
    • Yea I mean I know it exists, but finding (specifically) female BSPT to male NPT (i.e, to plug a Nissan OEM sensor into a 'standard' NPT port) was truly difficult. I don't think I'll recreate the setup I had in the past unless it's (possibly?) advisable with a stronger T piece made of steel, but who knows if the aluminium threads in the block become the next weak point etc. Given it may need to be redrilled out and something tapped into it, it'll need to be Female BSPT to the something that ends uo coming out of the side of the block.
    • Sounds like a perfect time to harness up a couple of the dogs, show the horses what real power is about!
