Mmm nothing like getting gravel fired into your skull by a world champion....
Solberg is done. Atkinson will take his place very soon. He has an awesome driving style - Balls to the wall, hook it in and hope for the best!
  • 3 weeks later...
  • Replies 181
  • 10 months later...
  • 4 weeks later...
