The Toyota "BUGGER" add for the Hilux.
The Honda Accord Euro add where all the parts move each other.
The Honda add the guy rides the motorcycle, drives the S2000 then the NSX then the F1 Car then the Ski boat and launches himself to the Hot air Balloon and rises from the water fall with HONDA written on the hot air balloon.
There was a Mitsubishi add for the EVO / Ralliart and they had a few scenes from import dvds and the EVO racing in a rally, that kinda stuff.
Those two ads are gold.
The Corolla seca sx commercial... it starts off with this little piglet making engine sounds and then he gets real mean and grows into a red boar... After that you see the red corolla seca sx
the series 2 s14 200sx commercial, from young boyhood dreams to reality, it worked well and im not just saying that because there is a series 2 200sx in my garage
Edited by alu-siv_stagea
name="allowFullScreen" value="true"></param><embed src="<A href="
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&">
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
here in nz satchi and satchi are a advertising company and
have always done toyota new zealand proud,
heres the latest one
The 1970's ads for the Torana's including the'When you're hot you're hot' ones referring to the bathurst victories, and the whole Hatch Hutch thing
LOL
*sings*
"torana hatch - its a car and a half!"
Oh man I feel so old :P
I agree Toyota NZ does have some funny adds
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
