The Toyota "BUGGER" add for the Hilux.
The Honda Accord Euro add where all the parts move each other.
The Honda add the guy rides the motorcycle, drives the S2000 then the NSX then the F1 Car then the Ski boat and launches himself to the Hot air Balloon and rises from the water fall with HONDA written on the hot air balloon.
There was a Mitsubishi add for the EVO / Ralliart and they had a few scenes from import dvds and the EVO racing in a rally, that kinda stuff.
Those two ads are gold.
The Corolla seca sx commercial... it starts off with this little piglet making engine sounds and then he gets real mean and grows into a red boar... After that you see the red corolla seca sx
the series 2 s14 200sx commercial, from young boyhood dreams to reality, it worked well and im not just saying that because there is a series 2 200sx in my garage
Edited by alu-siv_stagea
name="allowFullScreen" value="true"></param><embed src="<A href="
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&">
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
here in nz satchi and satchi are a advertising company and
have always done toyota new zealand proud,
heres the latest one
The 1970's ads for the Torana's including the'When you're hot you're hot' ones referring to the bathurst victories, and the whole Hatch Hutch thing
LOL
*sings*
"torana hatch - its a car and a half!"
Oh man I feel so old :P
I agree Toyota NZ does have some funny adds
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
