okay noobish question here but how is the RX8 allowed to run a turbo?
as long as a manfacturer made 10 of a car it can run. mazda made 10x turbo rx8s. Same story with the ATTKD Select R SP that Kel is in.
#819, David Ayers and Robbie Bolton, 1997 Nismo 400R
^^^This is a replica, right? Just came up on the feed they've gone off the road
yes, and its now a very good replica of a cube.
snowcone managed to lose no time at all with that off...the stage was downgraded to non-competitive after they crashed! I want to go in a lotto syndicate with him, I've never met anyone so lucky! Hope Chris is OK since it was his side
The motor is 100% ok. Fuel on the road for about 1km, we were only at half pace, rear end came around as we powered slowly out of a corner. We just watched the video. No fault of nav or driver. We still finished the stage and the stage was downgraded, so we didn't loose any time. Car still drives straight!
What are you doing Jesus! Wind the window down and do the big palm/fend to protect the car. Its like the Secret Service, you sign up to Nav you are committing to putting your life before the cars and drivers :cool:
Didnt you know the pace notes have a huge tree magnet in them. cars always go in navigator first.
Whish is what exactly? Its an R32 but with what done to it?
It has Black Cloth looking Bonnet, Pops n bangs and shoots flames... goes puuuu on lift off.
The rules have changed quite a bit and the AASA cars are getting fairly wild...
Becoming cheque book racing from machinery point of view... but Targa as a course is driver rewarding and there are a lot of cars with owners scratching their heads, and wondering why they didnt get an i30 or Mazda3 D.
TT
yeah early modern looks like "SAU class" doesn't it! Good work from Tim, obviously he hasn't had to read any stages backwards this year!
Roy, ATTKD Select is not a GTR, that is a different model of car. It does have many similar parts like the whole chasis. Engine is also very similar to NIssan's car but ATTKD's car has a larger stroke 2.8l, bigger cams and bigger turbos than the similar car from nissan.
And while I'm glad Kel is in such a damn good car....I really don't agree with what the current rules allow.
exactly correct. Mark and I are now building a short run of Raceworx Super Spartan Targa GTSTRs. We just need 8 more customers. They are about 1000kg, spaceframe, RB34DERT (super and turbo charged to help get the twin td06s spooling), hollinger sequential, carbon fibre body. They run 325 tyres on the rear and have 12 spot brakes, you would be a great customer. Best of all they run a Vipec ECU from the factory and include a 4th gear lock out for drag racing purposes. No rear seat either.
ayres car :(
I've still got my damaged 33 GTR shell under the house from last year's Targa with a perfectly good rear end. It might be just the thing for David to fix his car?
Cheers
Paul
Edited by poolheaters
I'd be devastated if that was my car (way too much blood, sweat and tears in in...some of them mine), but the truth is it is cheap and easy to reshell these cars. Other than the shell pretty much everything Mark is running this year rolled down a hill 7 times.
Changeover cost for a new shell is less than $10k which is a drop in the ocean compared to some of these builds. I know of a full, uncomplied 33 GTR with running motor going for 12k...once you sell the motor it doesn't cost much.
I guess snowy is going to need to reshell too, that one is seriously f**ked and I've never seen a "middle-cut".
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
