okay noobish question here but how is the RX8 allowed to run a turbo?
as long as a manfacturer made 10 of a car it can run. mazda made 10x turbo rx8s. Same story with the ATTKD Select R SP that Kel is in.
#819, David Ayers and Robbie Bolton, 1997 Nismo 400R
^^^This is a replica, right? Just came up on the feed they've gone off the road
yes, and its now a very good replica of a cube.
snowcone managed to lose no time at all with that off...the stage was downgraded to non-competitive after they crashed! I want to go in a lotto syndicate with him, I've never met anyone so lucky! Hope Chris is OK since it was his side
The motor is 100% ok. Fuel on the road for about 1km, we were only at half pace, rear end came around as we powered slowly out of a corner. We just watched the video. No fault of nav or driver. We still finished the stage and the stage was downgraded, so we didn't loose any time. Car still drives straight!
What are you doing Jesus! Wind the window down and do the big palm/fend to protect the car. Its like the Secret Service, you sign up to Nav you are committing to putting your life before the cars and drivers :cool:
Didnt you know the pace notes have a huge tree magnet in them. cars always go in navigator first.
Whish is what exactly? Its an R32 but with what done to it?
It has Black Cloth looking Bonnet, Pops n bangs and shoots flames... goes puuuu on lift off.
The rules have changed quite a bit and the AASA cars are getting fairly wild...
Becoming cheque book racing from machinery point of view... but Targa as a course is driver rewarding and there are a lot of cars with owners scratching their heads, and wondering why they didnt get an i30 or Mazda3 D.
TT
yeah early modern looks like "SAU class" doesn't it! Good work from Tim, obviously he hasn't had to read any stages backwards this year!
Roy, ATTKD Select is not a GTR, that is a different model of car. It does have many similar parts like the whole chasis. Engine is also very similar to NIssan's car but ATTKD's car has a larger stroke 2.8l, bigger cams and bigger turbos than the similar car from nissan.
And while I'm glad Kel is in such a damn good car....I really don't agree with what the current rules allow.
exactly correct. Mark and I are now building a short run of Raceworx Super Spartan Targa GTSTRs. We just need 8 more customers. They are about 1000kg, spaceframe, RB34DERT (super and turbo charged to help get the twin td06s spooling), hollinger sequential, carbon fibre body. They run 325 tyres on the rear and have 12 spot brakes, you would be a great customer. Best of all they run a Vipec ECU from the factory and include a 4th gear lock out for drag racing purposes. No rear seat either.
ayres car :(
I've still got my damaged 33 GTR shell under the house from last year's Targa with a perfectly good rear end. It might be just the thing for David to fix his car?
Cheers
Paul
Edited by poolheaters
I'd be devastated if that was my car (way too much blood, sweat and tears in in...some of them mine), but the truth is it is cheap and easy to reshell these cars. Other than the shell pretty much everything Mark is running this year rolled down a hill 7 times.
Changeover cost for a new shell is less than $10k which is a drop in the ocean compared to some of these builds. I know of a full, uncomplied 33 GTR with running motor going for 12k...once you sell the motor it doesn't cost much.
I guess snowy is going to need to reshell too, that one is seriously f**ked and I've never seen a "middle-cut".
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
