Yep Newton can steer alright, some of my favourite DECA vids are in-cars of big red... crazy
can you change diff ratios in targa? I reckon the 6 speed would be the way to go once you've got the 4.11 in there... but then again I'm with Brisby, I know a whole lot about nothing;)
Now now boys..... saying the 5 speed isn't a benefit but rather a cost saving is utter bullshit.
To win Targa first you have to finish it, so yes, reliability is very important (it is NOT however just a reliabilty trial, that is an insult).
Therefore, running the stonger, yet ILLEGAL, 5 speed box is definately a benefit.
Just because the R34's LEGAL gearbox is a six speed, does NOT make it instantly better. In fact, it's simply not, not for this type of racing. The R34 GTR is hopelessly tall geared, 6th never seeing use because the car won't pull it, and the diff gears are tall meaning less punch out of corners.
So cut the "it's not a performance enhancing mod so should be allowed" crap. That argument is baseless and I'll say it again, CRAP.
So, that's TWO plusses for the 5 speed box. The third (although how this matters when the event costs$20k to do) is cost.
I run an RB20 gearbox in my car, because that's what is legal. Everyone else running my model of car runs the RB25 gearbox, which is ILLEGAL. But, those slow guys don't get on the podium, therefore finishing the event is more important to them than legality, because the legality side of it will never worry them.
I have to be very aware of my weaker RB20 gearbox because as said, to do well you need to finish. And that is one of the other challenges with this event, you need to be aware of your particualr vehicle's weaknesses, and allow for same accordingly. Hey, the WRX guys have been doing it for years.
For all you guys saying improvements should be allowed for reliability, I'm sorry, you're simply wrong. Different cars need to have different strengths and weaknesses to keep it interesting.
I'm not aiming this at Snowy, he's a good fella, but a little reality check is needed here.
i didn't say it was or wasn't an improvement. I said it's irrelevant whether it's an improvement or not. the car was excluded because the gearbox it ran with is illegal under the rules not because it's more reliable, or because it's painted pink or because you put tenga egg sponsorship on it. :( none of those things matter. purely is it legal? yes = ok. no = exclusion. 100% I agree it should have been excluded. it broke the rules.
I agree standard 6th gear is useless for this kind of car and event. it makes your top speed purely academic as with the roads and the limited power you are never going to get there. but a close ratio 6 speed with stronger gears and geared to a top speed of say 260 or so is miles better than a 33 5 speed or a standard 34 getrag and is currently allowed under the rules (as I understand them a new gearset of same number of gears in standard casing is ok). my point was perhaps things need to change a little. evo guys can run 5 or 6 speed cause RS and GT models had the 5 speed CR box. it would be nice if 32 guys could run the 33 5 speed and let 34 drivers run either the 33 5speed or if they have the dough run a $$$ close ratio 6 speed. as I said the CR 6 is always going to be better than a 33 5 speed. but they are two separate debates. to make it clear of course if you break the rules you should be excluded and it wouldn't matter if the gearbox improved things or not. if it's against the rules you have to cop it.
ok, lol. speaking of boxes, for some entertainment check out this vid of a nice RX3 from 09 TT. check out the wacky shift action! it seems to me like 1st gear and 4th gear are in the same spot. which is where 3rd gear would normally be?!?! cause it goes first in the top middle, 2nd is top left, 3rd bottom left, 4th top middle 5th bottom middle. although I guess 1st is actually way over where 5th would be normally but in the vid it's hard to tell. certainly pretty confusing!
That must be a fairly popular shift pattern in dogboxes Beer Baron as the new PAR box in our gravel Sprinter is the same, and a mates IP RX7 is the same. I guess it gets first out of the way so you can just work the H pattern.
Shit is this still going on?
Hopefully once and for all...
1. The gearbox went in initially for financial reasons only. I don't care what anyone else thinks is the case.
2. After having driven both if I was allowed to choose I would pick the 32/33 no doubt. My reason would be simply because it is easier to drive than the 6 speed and its cheaper to maintain. I think both systems have their good and bad points from a performance view. I doubt my times would have been sweet F.A. different no matter which system I had in there.
3. I doubt there is a full running R34 drivetrain in tarmac out there anyways which is the funny part. Gearboxes are probably fine though but the rest is too hard to deal with.
4. I distinctly remember someone asking for a GTS4 diff during the event for a GTR.
5. Some people passing judgement should look closely in the mirror.
6. I'm over it and I'm going back to work.
I think the lay out is like this:
241
35
weird wankle people :O
Yup
Not necessarily a wankel thing (although they are a weird mob for various other reasons) :(
I had a Needham box for my RX2 which had the same pattern. Basically any RWD where you're chasing a 1:1 5th gear, you change the positions around so that 5th is where 4th used to be. Why? Because 4th is commonly 1:1 on RWD 5 speeds, and is actually direct drive (ie shafts are coupled together without any gear mesh) so very hard to change to any other ratio. This is the simplest way to do it, and the next logical progression is to keep the rest of the gears in a standard H pattern as much as possible. Since 1st is the least commonly usd gear, and it's not in the normal upshift sequence, it's easiest to put 1st where 5th used to be, and leave the rest in a standard H pattern.
Make sense? Simple
Yup
Make sense? Simple
make perfect sense and as a bonus looks hilarious! also might baffle someone stealing your car when they go to shift from '4th' up to '5th' and find themselves doing a 5th to 1st downchange instead.... yikes!
So anyway, whats next? High Country looks the goods! We're doing Mt Stuart next month as a nice little filler :P
Next for us in the Evo is High Country and it looks as though I have a seat for the ASP Adelaide Hills Tarmac Rally in 2 weeks... :P
That should help soothe the post Targa sads :P
So tell me what you really think? :P
Serious question now and I'm not trying to be smart:
What substantiation do you have behind your opinion that the 5 speed is stronger than the 6 speed getrag?
The reason I raise this is because of the following:
1. the infamous Racepace 33GTR with it's stroker motor and around 450rwkw sucessfully ran the 34 getrag in a few tarmac type events.
2. it is pretty much the same gearbox as the 6sp Supra and these cars aren't known to be serial gearbox killers, in fact are renowned to be able to handle high hp
3. why would nissan engineers put a weaker box into a later model gtr and plague its reputation with such a compromise?
you run top there you will get inspected
you dont run top three you wont
simple
question is? was the gear box the first thing the srews found or did they check the whole car and only find the box?
if it was the latter then snowy will be back and smash em next year
...do you want to go back there Duncan? The thread can be a like the 2008 F1 thread with M3GTR just repeating the same thing every post!
I am happy to go on posting my opinions (informed or otherwise ?!?!) on the matter but pretty sure people want to move on :blush:
So tell me what you really think? :thumbsup:
Serious question ....
....3. why would nissan engineers put a weaker box into a later model gtr and plague its reputation with such a compromise?
Think the thing is that since the R32, the Nissans have ran in modifiable classes... therefore the "engineer down to a price" rather than "up to a standard" comes into play. They put effort into seats n the like for the road punters.
My evo (showroom GSR - not RS) came with an MT/6, but even now - 5 years on - the prefered homoligation is MT/5.
I am tipping the Nissan engineers didnt engineer their OEM box to be subject to 300-400wkw, as during that time their factory race cars at a minimum were being fitted with dog boxes.
Dont forget most guys in Targa run aggressive paddle type clutches too which transfer more stress to the GB.
If I were an engineer building a street car as a race platform, the only parts "up-specd" would be those not allowed to be changed out in the target rules... my guess is Nissan too that approach maybe?
TT
Its funny, the R34 when it ran in the Ring 24hr races etc in Falken war paint, i recall it always had issues with turbo failures. Not gearbox.
But more importantly, Nissan are very competitive in their domestic market racing so Nismo are running around in the Super Taikyu series. Dont recall reading that it struggled with gearboxes, and there were several teams in the Super Taikyu series runnign R34s with std gearboxes...Falken, Endless amongst others and the GTRs did very well.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
